Launch Probe basic not in fullscreen
09 Feb 2025 08:50 #321049 by Martin.L
Launch Probe basic not in fullscreen was created by Martin.L
Is there a way to launch it in a smaller window (even if the text results small) so I can drag it somewhere in the screen while debugging?
The following user(s) said Thank You: Muftijaja
09 Feb 2025 18:08 #321080 by Lcvette
Replied by Lcvette on topic Launch Probe basic not in fullscreen
F11 toggles full screen so you can move it around
The following user(s) said Thank You: Muftijaja, TooTall18T
25 Feb 2025 00:25 #322545 by Muftijaja
Replied by Muftijaja on topic Launch Probe basic not in fullscreen
Have the same question since a while, because of HALshow while experimenting with some settings was not possible simultaneously.
Thank you for the question Martin, and Lcvette, for the answer!
Hanno
25 Feb 2025 01:23 #322548 by Lcvette
Yup, you can right click the hal show window and select always on top, and it will remain on top
Moderators: KCJ, Lcvette
Time to create page: 0.312 seconds
