Losing some values after PB restart
1 year 8 months ago #321758 by Lcvette
You need to make sure you have the latest subroutines files also
1 year 6 months ago - 1 year 6 months ago #326679 by IB_CnC
Small update:
After updating almost all values get stored and recalled correctly.
One exception seems to be the Spindle_zero.
If manually entered, it doesn't get stored and recalled.
If measured via subroutine, it does get stored an recalled on restart of PB.
(Subroutine folder is up to date)
Last edit: 1 year 6 months ago by IB_CnC.
1 year 6 months ago #327095 by Lcvette
yes because of all the confusion previously of how to calculate it I made it specific to the subroutine used to set it. not sure if I can make it both manually enterable and via subroutine easily or not. will have to take a look when i have some time again. I have been a bit covered up recently but hope in the next week or two to have some more time to work on the ui.
The following user(s) said Thank You: IB_CnC
1 year 6 months ago #327266 by Jedi
Good Day,
What is the correct way to update ProbeBasic from a very old version?
sudo apt-get update/sudo apt-get upgrade does nothing.
Best Regards,
Ben
1 year 6 months ago #327323 by IB_CnC
Are you sure the probe_basic config folder doesn't get updated when you run those commands?
I was looking at the wrong machine folder initially, because I made a copy of probe_basic base folder when I first installed it.
1 year 6 months ago #327379 by Jedi
I will Check again.
and let you know. Is there a terminal command to see witch version is installed?
Best regards,
Ben
Moderators: KCJ, Lcvette
Time to create page: 0.066 seconds
