Losing some values after PB restart
- IB_CnC
- Thank you received: 14
09 Feb 2025 13:41 #321062
by IB_CnC
Losing some values after PB restart was created by IB_CnC
Small question, after I restart PB I lose the values in the Probe screen and the settings for the Tool setter (like spindle head distance).
How are those retained normally? It didn't happen at first, so must have happened while editing .HAL and .INI.
Tool offsets and WCO do get saved, no issue with those.
- Lcvette
- Thank you received: 783
09 Feb 2025 18:04 #321078
by Lcvette
Replied by Lcvette on topic Losing some values after PB restart
you must have recently done an update? the var file as well as the subroutine folder requires updating. ALWAYS check the status page after running an apt update as sometimes when major changes are implemented in probe basic the configuration files will require updating. this is one of those scenarios.
to verify you can install meld (sudo apt install meld) and run a directory comparison to see the files that have changed in the configuration folder and subroutine folder.
once you complete the updates you should be back to normal operation!
- IB_CnC
09 Feb 2025 18:51 #321092
by IB_CnC
Replied by IB_CnC on topic Losing some values after PB restart
The strange thing is I haven't ran an update for quite a long time.
I have been doing a lot of configuration work in HAL and INI files.
I will check with meld, create a backup and perform an update anyway to see if it fixes the problem, thanks!
- Lcvette
09 Feb 2025 19:16 #321098
by Lcvette
the user parameters require the var file to have the numbered variable listed in the file, this makes them persistent, if they are not in the file they are volatile which will work if entered in the ui for that instance but not be stored. the ui also has a settings storage method and this can become unsynched if the var file is missing the listed parameter numbers. it is an issue we are trying to resolve but as long as everything is in place it works as expected without issue.
the subroutines contain update parameter subs which are responsible for writing the newly ui entered parameters to the var file. so those need to be in place too!
- Lcvette
09 Feb 2025 19:17 #321099
by Lcvette
I would run an apt update to make sure you are on the latest probe basic to ensure your sim config contains the most recent updates
The following user(s) said Thank You: IB_CnC
- IB_CnC
09 Feb 2025 20:11 #321110
by IB_CnC
Will do tomorrow and post the results!
- IB_CnC
16 Feb 2025 11:08 #321715
by IB_CnC
- Lcvette
16 Feb 2025 11:20 #321720
by Lcvette
You are on a very old version, chances are you have the wrong subroutines for the version you are on. Update to the latest stable version to resolve.
- IB_CnC
16 Feb 2025 12:53 - 16 Feb 2025 12:54 #321732
by IB_CnC
Last edit: 16 Feb 2025 12:54 by IB_CnC.
The following user(s) said Thank You: Lcvette
- Lcvette
16 Feb 2025 13:00 - 16 Feb 2025 13:02 #321733
by Lcvette
excellent, glad to hear it!
fyi, your jog increments can be set in the ini file to avoid them being stacked on top of each other like that. the stock increments are typically more than are needed for actual functional use. I find 3-4 increments plus jog are sufficient for all situations.
Last edit: 16 Feb 2025 13:02 by Lcvette.
Moderators: KCJ, Lcvette
Time to create page: 0.202 seconds
