Probe Basic Lathe
16 Feb 2025 09:48 #321695 by gastlth1
Probe Basic Lathe was created by gastlth1
Hello everyone,
I have installed the Probe Basic Lathe version 2.9.4.
1. The simulation works fine, when I want to change a tool I get a popup window and can confirm the tool number - the tool number in each tab changes without error.
When I install it for the 7i96s configuration, I can open it - turn it on - the stepper motors work in MAN mode - referencing also works, but when I want to change the tool, nothing happens and the system freezes.
I get the message: can`t issue mid unless machine is on, homed and idle.
2. When I want to use the macros in the conversation tab - change values and start - nothing happens.
How can I fix these problems?
16 Feb 2025 09:53 #321697 by Aciera
Replied by Aciera on topic Probe Basic Lathe
please post your config folder (compress and attach)
The following user(s) said Thank You: Lcvette
19 Feb 2025 16:40 #322001 by Lcvette
Replied by Lcvette on topic Probe Basic Lathe
you need to update the config files for manual toolchange per the docs here:
kcjengr.github.io/probe_basic/machine_config.html
Moderators: KCJ, Lcvette
Time to create page: 0.578 seconds
