- Thank you received: 784
Move Machine to inside soft limits when Probe Basic on
- Lcvette
1 year 8 months ago - 1 year 8 months ago #322450
by Lcvette
Replied by Lcvette on topic Move Machine to inside soft limits when Probe Basic on
My machine is setup same as they probe_basic.ini in the sim. Homes z up, table right, table front.
It could be also that your axis motors are turning the wrong direction of things aren't making sense.
Last edit: 1 year 8 months ago by Lcvette.
- aikiaviator
1 year 8 months ago #322452
by aikiaviator
Replied by aikiaviator on topic Move Machine to inside soft limits when Probe Basic on
Ok, so my Z is configured correctly with 0 top and negative moving down as Z+ is top and Z- is down correct? Or should I change some of the config values?
I need to adjust X so zeroing on left edge of table. So will swap zero and set to left edge. I can do that. And Y, I could zero front edge of table (moving to rear) just made me a little concerned as no limit switch and crash would be at back. Wanted limit switch on moving backwards. Any thoughts on this aspect...
- Lcvette
1 year 8 months ago - 1 year 8 months ago #322456
by Lcvette
I zero y table moving full front and sets zero. travel directions will always remain the same in the Cartesian coordinate system.
- Thank you received: 4153
1 year 8 months ago #322465
Replied by rodw on topic Move Machine to inside soft limits when Probe Basic on
Back to the centre home position, you touch off using G54 offsets to achieve this in the work piece
linuxcnc.org/docs/2.4/html/gcode_coordinates.html
Here is an example part where you would touch off on the centre of the part as everything needs to be concentric of the centre bore.
This does not affect the machine home position
- aikiaviator
1 year 8 months ago #322484
by aikiaviator
Hi lcvette, Ok, so looked at the probe_basic.ini, and apart from the X axis, my setup is the same. Z is 0 to -ve, Y is 0 to -ve, and X is 0 to +ve. So apart from the X axis my information is the same. Is that your understanding?
- Lcvette
1 year 8 months ago #322488
by Lcvette
ve?
Moderators: KCJ, Lcvette
Time to create page: 0.255 seconds
