No Keyboard jog after update 2.9.3 to 2.9.4
24 Feb 2025 20:15 #322526 by Ismacr63
I was on 2.9.3 and today I updated to 2.9.4
After the update the Jog from the keyboard no longer works.
If I press the buttons with the mouse they work.
In the ini file I have KEYBOARD_JOG=1 enabled
Does anyone know what the problem could be?
25 Feb 2025 01:21 - 26 Feb 2025 14:40 #322547 by Lcvette
Replied by Lcvette on topic No Keyboard jog after update 2.9.3 to 2.9.4
A couple safety levels were added, make sure both of the following are added for keyboard jogging.
KEYBOARD_JOG = true
Ctrl+jog key will work.
KEYBOARD_JOG_SAFETY_OFF = true
Removes need for Ctrl key
Last edit: 26 Feb 2025 14:40 by Lcvette.
The following user(s) said Thank You: Unlogic
25 Feb 2025 11:22 - 25 Feb 2025 12:12 #322577 by Ismacr63
Replied by Ismacr63 on topic No Keyboard jog after update 2.9.3 to 2.9.4
thank you so much. Before I used Shift for fast movement. Now it doesn't work, can it be activated somehow? Is there a changelog where I can see basic probe changes?
Last edit: 25 Feb 2025 12:12 by Ismacr63.
26 Feb 2025 14:50 #322704 by Lcvette
in probe basic? i don't recall ever having a feedoveride via shift. i do not see anything to that effect in the code. was this in a different ui?
26 Feb 2025 15:15 #322709 by Ismacr63
It is not a cancellation, it is a speed increase. When you press the keys to move along the axes it moves at a speed of, for example, 360 and when you press the shift key + the movement key it moves at a much higher speed. I have always used that in probe basic and in any other Linuxcnc interface. but since update 2.9.4 it doesn't work for me.
26 Feb 2025 15:50 #322713 by Lcvette
not sure if that is in a linuxcnc update thing or not, i would ask in the general chat maybe. i can confirm in 2.9.3 here shift key does not change the jog speed. so i'm not certain where the disconnect occurred. from some quick research it appears gmoccapy used the shift key to double the default linear velocity setting, but i do not see in linuxcnc where this is a standard and I know i never wrote that functionality into probe basic. in probe basic the only control over the jog speed that is built into the ui is the jog slider.
26 Feb 2025 18:54 #322727 by Ismacr63
It's strange because it has always worked like this for me in Probe Basic and also previously using other interfaces.
Is there any possibility of continuing to use it?
26 Feb 2025 19:34 #322732 by Lcvette
I took a look and was able to add shift modifer which will make shift key use the max velocity ini setting as the override speed. I tested here and it works in all levels of safety, I need a few independent tests done before i push to the develop branch.
26 Feb 2025 20:49 #322744 by Ismacr63
I have created a new configuration for axis and the option to move faster by pressing shift plus the movement keys works, and in Probe Basic I can confirm that it worked before the update.
If I can help you test something, let me know.
26 Feb 2025 21:24 #322752 by Lcvette
currently the "+" key in combination with a keyboard jog key will run at max speed, the "-" key in combination with a keyboard jog key will run at 10% of the jog speed slider adjusted speed. so you do have access currently to speed overrides with the keyboard in probe basic.
Moderators: KCJ, Lcvette
Time to create page: 0.423 seconds
