Permanent probing parameters
10 Mar 2025 20:33 #323632 by Stran_ge
Permanent probing parameters was created by Stran_ge
Hey,
are the probing parameters supposed to be reset after every pc restart or should they stay in the .var file.
For some reason after a pc restart they always revert to very old settings that i set long time ago.
Bst regards
Nils
10 Mar 2025 23:39 - 10 Mar 2025 23:40 #323639 by Lcvette
Replied by Lcvette on topic Permanent probing parameters
Update your subroutines folder and add the var file parameters per the instructions on the splash page. Will fix your issue. Use the sim config folder for reference.
Last edit: 10 Mar 2025 23:40 by Lcvette.
11 Mar 2025 14:26 #323682 by Stran_ge
Replied by Stran_ge on topic Permanent probing parameters
I did update the subroutines folder for the latest Version of probe basic.
So do i have to manually go and edit the probe_basic.var?
11 Mar 2025 14:35 - 11 Mar 2025 15:35 #323683 by Stran_ge
Nvm i got it working. I forgot to actualy update the .var file itself so it startet at number 5xxx and not 3xxx.
So new parameters couldnt be stored.
Last edit: 11 Mar 2025 15:35 by Stran_ge.
11 Mar 2025 15:05 #323684 by Lcvette
Great, glad you got it sorted!
Moderators: KCJ, Lcvette
Time to create page: 0.163 seconds
