ATC carosel
- Sternfox
- Thank you received: 7
19 Mar 2025 11:31 #324284
by Sternfox
ATC carosel was created by Sternfox
Hi guys,
Is there any documentation yet for a carosel atc? Or dose pb use the standard lcnc tool change?
Also I have dc motors on my atc that use pwm can thesr be used or do i need steppers?
- pommen
- Thank you received: 19
19 Mar 2025 16:24 #324304
by pommen
Replied by pommen on topic ATC carosel
Does this help?
linuxcnc.org/docs/html/man/man9/carousel.9.html
- Lcvette
- Thank you received: 784
22 Mar 2025 13:05 #324546
by Lcvette
Replied by Lcvette on topic ATC carosel
the probe basic atc sim has the macros setup in the config files to be used as a template, have a look at toolchange.ngc and M10 thru M26.ngc in the subroutines folder.
Moderators: KCJ, Lcvette
Time to create page: 0.267 seconds
