Porbe basic lathe: Questions about the keyboard
02 Apr 2025 22:44 #325557 by Ismacr63
Well, back here with some questions.
Just like what happened to me with the mill, in the lathe interface I've enabled keyboard jog and disabled the safety key, but it has no effect and I have to keep holding the Ctrl/Alt key. The + key for fast forward doesn't work. Is there any way to change it?
The keys for moving the axes with the keyboard are the same as those for the mill, and it's very inconvenient because they're separated. Can I change it so it moves the same as the axis?
02 Apr 2025 23:58 #325560 by Lcvette
Are you on stable or develop version?
03 Apr 2025 07:03 #325589 by Ismacr63
I'm on the stable version
03 Apr 2025 10:38 #325602 by Ismacr63
I've discovered that if I click inside the grid (where the ZX axis is shown), the movement buttons work, but at maximum speed, when I press the + key, it starts working as it's supposed to. When I click somewhere else, it stops working, and I have to do everything again. I assume it's due to some unknown issue.
I've also noticed that the maximum motor speeds increase at random startups without making any changes to the files.
The movement keys on the keyboard are still like a mill and aren't very comfortable to use.
01 May 2025 13:22 #327431 by Lcvette
not sure i follow about the speeds thing? maybe your configuration settings for default jog speed? not sure about the keys things, been completely covered up with work and haven't had any time to dig into probe basic recently. maybe ask the linuxcnc devs if they could add a keyboard assignment to the configuration? for lathe? if its such an issue im sure more folks would want a global resolution that translates into any gui running the lathe option in the ini.
04 May 2025 20:44 #327709 by Ismacr63
I think the problem with the keys is with the probe basic interface because it works perfectly on axis.
22 May 2025 02:31 #328887 by Lcvette
I'll take a look when I get some more time, I spent today on another issue I've run across, but hopefully in the next few days I'll have a few minutes to investigate the keyboard thing.
05 Jun 2025 06:05 #329726 by Lcvette
ok i have reworked keyboard jogging, it now has the following functionality and is available in the latest apt install for develop branch.
ini settings:
KEYBOARD_JOG = true
(turns keyboard jogging on)
KEYBOARD_JOG_SAFETY_OFF = true
(removes the need for the control key)
shift key + jog key will give you rapid jog speed (works in safety mode and normal mode)
jog key gives you jog speed with jog feed override slider percentage applied
Probe Basic Lathe uses the following for keyboard jogging:
Left and Right arrow keys for Z axis
Up and Down arrow keys for X Axis
(in the display section, set one of the following entries only, LATHE is for front tool post, BACK_TOOL_LATHE is for rear mounted tool post)
[DISLPLAY]
LATHE = 1
(this makes X Positive direction jog key the down arrow key)
BACK_TOOL_LATHE = 1
(this makes X Positive direction jog key the up arrow key)
I think these all make sense and follow the linuxcnc std a little more closely!
Best Regards,
Chris
Moderators: KCJLcvette
Time to create page: 0.131 seconds
