Probe_basic paramters not updating.
- Philip Lydin
- Thank you received: 6
05 Apr 2025 10:47 #325752
by Philip Lydin
Probe_basic paramters not updating. was created by Philip Lydin
Im working on setting up my 4 button tool setter for my lathe and in the probing routine i need to know which orientation the tool is so it knows if it needs to probe in x - or x+. the tool orientation is supposed to be in parameter #3013 but it doesnt update and always stays at zero. i am on the development version and i am using the sim.var paramter file. regards Philip
- Lcvette
- Thank you received: 782
06 Apr 2025 12:55 #325814
by Lcvette
Replied by Lcvette on topic Probe_basic paramters not updating.
Are you using the mill version? I don't think I ever set up large for probing yet because I had no tool setter. Tell me more about what you're doing. The parameters are for the mill UI.
- Philip Lydin
16 Apr 2025 16:31 #326475
by Philip Lydin
Replied by Philip Lydin on topic Probe_basic paramters not updating.
aha ok im using the lathe version
- Lcvette
22 May 2025 02:32 - 22 May 2025 02:33 #328888
by Lcvette
Yeah Lathe UI is still using the old settings method, it will get updated in the future after the next major mill release.
Last edit: 22 May 2025 02:33 by Lcvette.
Moderators: KCJ, Lcvette
Time to create page: 0.259 seconds
