Install Probe Basic
1 year 5 months ago #328639 by Doc_emmet
Replied by Doc_emmet on topic Install Probe Basic
I've installed everything.
Also:
sudo apt update
sudo apt --fix-broken install
sudo apt install python3-qtpyvcp
sudo apt install python3-probe-basic
cd ~
mkdir dev
cd dev
git clone github.com/Lcvette/qtpyvcp-bookworm-installer.git
cd qtpyvcp-bookworm-installer
./install_for_qtpyvcp.sh
./updater.sh
And yet I still get this error:
File "/usr/bin/probe_basic", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3/dist-packages/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/usr/lib/python3/dist-packages/qtpyvcp/__init__.py", line 26, in run_vcp
run(*args, **kwargs)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/__init__.py", line 129, in run
launch_application(opts, config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 78, in launch_application
loadWindows(config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 230, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 210, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 53, in __init__
self.load_user_tabs()
File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 87, in load_user_tabs
user_tab_folders = os.listdir(user_tabs_path)
FileNotFoundError: [Error 2] File or directory not found: 'user_tabs/ # REQUIRED Setting for Probe Basic'
Where is the 'user_tabs/' folder supposed to be? I've moved it to:
linux/configs and, just to be on the safe side, to linux/configs/My_Machine
1 year 5 months ago - 1 year 5 months ago #328642 by Aciera
Replied by Aciera on topic Install Probe Basic
I don't really know but it seems to be set in the ini file:
Last edit: 1 year 5 months ago by Aciera.
1 year 5 months ago #328648 by Benb
Replied by Benb on topic Install Probe Basic
If you installed linuxcnc as RIP,  before running qtpyvcp execute the following command at the prompt:
source ~/your rip path/linuxcnc/scripts/rip-environment
Note you don't need to run linuxcnc just source its environment this allows qtpyvcp to find what it needs  to run
1 year 5 months ago #328656 by Doc_emmet
Hello, I've finally found the error.
The problem is caused by importing entries from the "pb_required_ini_settings.ini" file.
This is the file:
[DISPLAY]
DISPLAY = probe_basic
OPEN_FILE = ~/linuxcnc/nc_files/pb_examples/blank.ngc
CONFIG_FILE = custom_config.yml
MAX_FEED_OVERRIDE = 2.000000            # Recommended Setting for Probe Basic
MAX_SPINDLE_OVERRIDE = 2.000000         # Recommended Setting for Probe Basic
MIN_SPINDLE_OVERRIDE = 0.500000         # Recommended Setting for Probe Basic
INCREMENTS = JOG .01in .001in .0001in   # REQUIRED Setting for Probe Basic
USER_TABS_PATH = user_tabs/             # REQUIRED Setting for Probe Basic
USER_BUTTONS_PATH = user_buttons/       # REQUIRED Setting for Probe Basic
[RS274NGC]
RS274NGC_STARTUP_CODE = F10 S300 G20 G17 G40 G49 G54 G64 P0.001 G80 G90 G91.1 G92.1 G94 G97 G98
PARAMETER_FILE = probe_basic.var
OWORD_NARGS = 1
NO_DOWNCASE_OWORD = 1
SUBROUTINE_PATH = subroutines
[HAL]
POSTGUI_HALFILE = probe_basic_postgui.hal
TWOPASS = on
And here's the error: USER_TABS_PATH = user_tabs/ # REQUIRED Setting for Probe Basic
There must be no comments after USER_TABS_PATH = user_tabs/, no "#" because that causes the error!!!
The following user(s) said Thank You: tommylight, Benb
1 year 5 months ago #328867 by Lcvette
Replied by Lcvette on topic Install Probe Basic
correct, this is explained int he instructions to remove the comments or you will receive errors.
1 year 5 months ago #328884 by Lcvette
If you follow the instructions carefully it takes about an hour start to finish including creating and installing Linux on a clean system. I do it every few days for new builds and testing and it's not too bad considering what it is. The machine setup is the most challenging and that is really such a unique to user thing that is hard to make it simpler.
The following user(s) said Thank You: tommylight, Unlogic
Moderators: KCJ, Lcvette
Time to create page: 0.260 seconds
