Install Probe Basic
1 year 5 months ago - 1 year 5 months ago #328591 by Benb
Replied by Benb on topic Install Probe Basic
Try this qtpyvcp installation script:
github.com/Lcvette/qtpyvcp-bookworm-installer
You might have to start with clean debian/linucnc install
Last edit: 1 year 5 months ago by Benb.
1 year 5 months ago #328597 by Doc_emmet
Replied by Doc_emmet on topic Install Probe Basic
Thank you very much for your help. I first installed www.debian.org/devel/debian-installer/ as described without any errors. Then I run:
cd ~
cd Downloads
sudo dpkg -i linuxcnc-uspace_2.9.3_amd64.deb
and I get these messages. Why these dependency problems? Or are these messages normal?
dg@LinuxCNC:~/Downloads$ sudo dpkg -i linuxcnc-uspace_2.9.3_amd64.deb
[sudo] Password for dg:
(Reading database... 119436 files and directories are currently installed.)
Preparing to unpack linuxcnc-uspace_2.9.3_amd64.deb...
Unpacking linuxcnc-uspace (1:2.9.3) via (1:2.9.3)...
dpkg: Dependency problems prevent configuration of linuxcnc-uspace:
linuxcnc-uspace depends on python3 (<< 3.12); but:
Version of Python3 on the system is 3.13.3-1.
linuxcnc-uspace depends on libboost-python1.74.0 (>= 1.74.0+ds1); but:
Package libboost-python1.74.0 is not installed.
linuxcnc-uspace depends on libboost-python1.74.0-py311; but:
Package libboost-python1.74.0-py311 is not installed.
linuxcnc-uspace depends on libgpiod2 (>= 1.5.1); but:
Package libgpiod2 is not installed.
linuxcnc-uspace depends on libmodbus5 (>= 3.1.4); but:
Package libmodbus5 is not installed.
linuxcnc-uspace depends on libpython3.11 (>= 3.11.0); but:
Package libpython3.11 is not installed.
linuxcnc-uspace depends on libtk8.6 (>= 8.6.0); but:
Package libtk8.6 is not installed.
linuxcnc-uspace depends on libudev-dev; but:
Package libudev-dev is not installed.
linuxcnc-uspace depends on iptables; but:
Package iptables is not installed.
linuxcnc-uspace depends on blt; but:
Package blt is not installed.
linuxcnc-uspace depends on mesa-utils; but:
Package mesa-utils is not installed.
linuxcnc-uspace depends on python3-tk; but:
Package python3-tk is not installed.
linuxcnc-uspace depends on python3-numpy; but:
Package python3-numpy is not installed.
linuxcnc-uspace depends on python3-opengl; but:
Package python3-opengl is not installed.
linuxcnc-uspace depends on python3-configobj; but:
Package python3-configobj is not installed.
linuxcnc-uspace depends on python3-xlib; but:
Package python3-xlib is not installed.
linuxcnc-uspace depends on libgtksourceview-3.0-dev; but:
Package libgtksourceview-3.0-dev is not installed.
linuxcnc-uspace depends on tcl8.6; but:
Package tcl8.6 is not installed.
linuxcnc-uspace depends on tk8.6; but:
Package tk8.6 is not installed.
linuxcnc-uspace depends on bwidget (>= 1.7); but:
Package bwidget is not installed.
linuxcnc-uspace depends on tclreadline; but:
Package tclreadline is not installed.
linuxcnc-uspace depends on tclx; but:
Package tclx is not installed.
linuxcnc-uspace depends on python3-pyqt5; but:
Package python3-pyqt5 is not installed.
linuxcnc-uspace depends on python3-pyqt5.qsci; but:
Package python3-pyqt5.qsci is not installed.
linuxcnc-uspace depends on python3-pyqt5.qtsvg; but:
Package python3-pyqt5.qtsvg is not installed.
linuxcnc-uspace depends on python3-pyqt5.qtopengl; but:
Package python3-pyqt5.qtopengl is not installed.
linuxcnc-uspace depends on python3-opencv; but:
Package python3-opencv is not installed.
linuxcnc-uspace depends on python3-espeak; but:
Package python3-espeak is not installed.
linuxcnc-uspace depends on python3-dbus.mainloop.pyqt5; but:
Package python3-dbus.mainloop.pyqt5 is not installed.
linuxcnc-uspace depends on python3-pyqt5.qtwebengine | python3-pyqt5.qtwebkit; but:
Package python3-pyqt5.qtwebengine is not installed.
Package python3-pyqt5.qtwebkit is not installed.
linuxcnc-uspace depends on espeak-ng; but:
Package espeak-ng is not installed.
linuxcnc-uspace depends on pyqt5-dev-tools; but:
Package pyqt5-dev-tools is not installed.
linuxcnc-uspace depends on gstreamer1.0-tools; but:
Package gstreamer1.0-tools is not installed.
linuxcnc-uspace depends on espeak; but:
Package espeak is not installed.
linuxcnc-uspace depends on python3-poppler-qt5; however:
Package python3-poppler-qt5 is not installed.
linuxcnc-uspace depends on psmisc; however:
Package psmisc is not installed.
dpkg: Error processing package linuxcnc-uspace (--install):
Dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.41-7)...
Processing triggers for mailcap (3.74)...
Processing triggers for desktop-file-utils (0.28-1)...
Processing triggers for hicolor-icon-theme (0.18-2)...
Processing triggers for man-db (2.13.1-1)...
Processing triggers for shared-mime-info (2.4-5+b2)...
Errors occurred processing:
linuxcnc-uspace
dg@LinuxCNC:~/Downloads$ sudo apt install git
Try "apt --fix-broken install" to correct this.
Unmet Dependencies:
git: Depends on: liberror-perl but should not be installed
Depends on: git-man (> 1:2.47.2) but should not be installed
Depends on: git-man (< 1:2.47.2-.) but should not be installed
Recommends: Patch but should not be installed
linuxcnc-uspace: Depends on: py
1 year 5 months ago #328600 by Benb
Try loading this dependencies and then install Linuxcnc (these dependevies are for the so called run in place RIP Linuxcnc installation, its a compiled installation) but it might help you with your deb method installation (in my case I refer rip). At the command prompt issue the following command:
Sudo apt install –y debhelper-compat dh-python libudev-dev docbook-xsl asciidoc imagemagick asciidoc-dblatex autoconf automake bwidget gettext intltool libboost-python-dev libepoxy-dev libgl-dev libgl1-mesa-dev libglu1-mesa-dev libgtk2.0-dev libgtk-3-dev libmodbus-dev libgpiod-dev libeditreadline-dev libusb-1.0-0-dev libxmu-dev po4a psmisc python3-dev python3-tk python3-xlib tcl8.6-dev tk8.6-dev xvfb yapps2 dblatex dvipng fonts-dejavu graphviz groff inkscape python3-lxml source-highlight texlive-extra-utils texlive-font-utils texlive-fonts-recommended texlive-lang-cyrillic texlive-lang-european texlive-lang-french texlive-lang-german texlive-lang-polish texlive-lang-spanish texlive-latex-recommended w3c-linkchecker xsltproc texlive-xetex
1 year 5 months ago - 1 year 5 months ago #328601 by Doc_emmet
Last edit: 1 year 5 months ago by Doc_emmet.
1 year 5 months ago #328602 by Doc_emmet
Hello, it looks like I've found the error.
It's related to my Mini PC
GMKtec K11 AMD Ryzen 9 Gaming Mini PC 8945HS(8C/16T, up to 5.2GHz),
32GB DDR5 4800MHz RAM 1TB PCIE Mini Computer, Oculink,
Dual NIC 2.5GbE LAN/HDMI/USB 4.0/WiFi 6/BT 5.2/DisplayPort/USB4*2
When I install the software on my old Intel i7 4 cores,
there are no error messages and the jitter is also better.
But it won't install on a new AMD Ryzen 9 PC.
1 year 5 months ago - 1 year 5 months ago #328603 by Benb
Your amd pc is a new hardware and you might need debian 13 Trixie but again you did not have problems loading debian bookworm mistry! If you want to try Linuxcnc rip installation which might work with your amd pc since its compiled. I have atttached is a step by step procedure. It worked for me using i5 mini pc with debian 12 bookworm RT with xfce option for desktop environment.
edit: Once linuxcnc installed follow this procedure to instal qtpyvcp
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Moderators: KCJ, Lcvette
Time to create page: 0.347 seconds
