Cant del Offset table and save
- Kittifix
08 Jun 2025 13:32 - 08 Jun 2025 22:15 #329945
by Kittifix
Cant del Offset table and save was created by Kittifix
after probing Edge Angle the R is set and now i want remove for a new Operation
in the Tab Offsets i can clear all or clear selected or one - save and i get this Errors
Last edit: 08 Jun 2025 22:15 by Kittifix.
- Lcvette
- Thank you received: 782
08 Jun 2025 14:18 #329950
by Lcvette
Replied by Lcvette on topic Cant del Offset table and save
is your machine 5 axis using xyzac?
- Kittifix
08 Jun 2025 15:57 #329956
by Kittifix
Replied by Kittifix on topic Cant del Offset table and save
Config only for XYZ
- Lcvette
08 Jun 2025 17:09 - 08 Jun 2025 17:11 #329960
by Lcvette
need to update your config with all parameters to set the correct columns, it is calling for a axis to be set but you have no a axis configured.
kcjengr.github.io/probe_basic/machine_config.html
please ensure your config settings are correctly set for 3 axis XYZ and offset table is correctly set for XYZR and report back if that resolves!
Last edit: 08 Jun 2025 17:11 by Lcvette.
- Lcvette
08 Jun 2025 17:20 #329961
by Lcvette
if you are not on the latest release of probe basic, the offsets column setup is in the custom_config.yml file, change the columns to display to XYZR then save the file and restart probe basic and retry.
The following user(s) said Thank You: Kittifix
- Kittifix
08 Jun 2025 17:42 #329962
by Kittifix
Great,Großartig ,Thank You,Dankeschön !!!
Step by Step ,my little Smurf come to become ready
Latency - best i can get from this Thing called Gurke
Motion - ready
Toolsetter - works fine
Probing - Great
Spindel -
Yeehaaa, it was the custom_config.ymlif you are not on the latest release of probe basic, the offsets column setup is in the custom_config.yml file, change the columns to display to XYZR then save the file and restart probe basic and retry.
Motion - ready
Probing - Great
Spindel -
The following user(s) said Thank You: Lcvette
- Lcvette
09 Jun 2025 03:45 #329992
by Lcvette
glad you got it sorted out!
Moderators: KCJ, Lcvette
Time to create page: 0.259 seconds
