Jog Increments based on G20 or G21
12 Jun 2025 01:21 #330182 by kubes
Jog Increments based on G20 or G21 was created by kubes
Hello,
Can the INCREMENTS be dynamic by G20 (in) or G21 (mm)?
In my .ini / DISPLAY
INCREMENTS = JOG  .010in .001in .0001in
INCREMENTS = JOG  .100mm .010mm .001mm
12 Jun 2025 03:57 #330189 by Lcvette
Replied by Lcvette on topic Jog Increments based on G20 or G21
Yes you can have either in or mm to specify what is displayed.
12 Jun 2025 04:03 #330190 by kubes
Replied by kubes on topic Jog Increments based on G20 or G21
Thanks.
I want to jog in inch increments when in G20, and have it change to mm increments when using G21. Similar to the DRO when it changes.
12 Jun 2025 04:10 #330191 by Lcvette
INCREMENTS = 1 mm, .5 in, ... - Defines the increments available for incremental jogs. The INCREMENTS can be used to override the default. The values can be decimal numbers (e.g., 0.1000) or fractional numbers (e.g., 1/16), optionally followed by a unit (cm, mm, um, inch, in or mil). If a unit is not specified the machine unit is assumed. Metric and imperial distances may be mixed: INCREMENTS = 1 inch, 1 mil, 1 cm, 1 mm, 1 um is a valid entry.
From the docs. I don't think you can change on the fly since it in the initialization file. I could be wrong, but you can mix and match to suit your needs. I rarely use any besides the fine feed. Could probably get away with 4 units, jog, mm, mm, in, in
Moderators: KCJLcvette
Time to create page: 0.201 seconds
