Probe Basic Screen missing axes
- Roger S
- Thank you received: 5
07 Jul 2025 15:51 - 07 Jul 2025 16:22 #331455
by Roger S
Probe Basic Screen missing axes was created by Roger S
Last edit: 07 Jul 2025 16:22 by Roger S.
- Roger S
07 Jul 2025 16:36 #331462
by Roger S
Replied by Roger S on topic Probe Basic Screen missing axes
Hello Langdons,
Even with clean and autoremove, the axes are missing in the GUI
- Roger S
07 Jul 2025 18:00 #331471
by Roger S
I've suspended a new system. Before the computer goes offline and goes into the basement, I wanted to bring everything up to date again.
The repair was unsuccessful.
- Lcvette
- Thank you received: 782
07 Jul 2025 22:07 #331492
by Lcvette
Replied by Lcvette on topic Probe Basic Screen missing axes
- Lcvette
07 Jul 2025 22:14 - 07 Jul 2025 22:20 #331493
by Lcvette
Also, anytime you update if there is something missing in probe basic using your machine config on program open, check the probe basic simulation from within the linuxcnc sims. It will always have any updated requirements performed. If the sim opens and appears normal, then it's a safe bet that it's your machine configuration requiring new updates. We put information right on the status page that is updated with new releases with a link to any requirements due to upgrades in probe basic. Always start there.
Last edit: 07 Jul 2025 22:20 by Lcvette.
- Roger S
08 Jul 2025 04:55 #331503
by Roger S
A classic case of RTFM... Thanks Lcvette, I'll check it out tonight
The following user(s) said Thank You: Lcvette
- Lcvette
16 Jul 2025 21:44 #331913
by Lcvette
Get everything squared away?
- emclinuxer
25 Aug 2025 10:15 #333894
by emclinuxer
Replied by emclinuxer on topic Probe Basic Screen missing axes
Hello , i've got the same Problem but the manual doesn't help me.
Have you solved this problem?
- Lcvette
27 Aug 2025 03:12 #333973
by Lcvette
Docs have the required settings and files that are needed, read through the notes section and make sure you have the folders required in your config folder and the correct in settings.
- emclinuxer
04 Sep 2025 17:50 #334422
by emclinuxer
Thank you,
after i have had read the manual i could solve the problem.
Moderators: KCJ, Lcvette
Time to create page: 0.584 seconds
