Carousel don t stop when estop is pushed
- Retrofit
10 Sep 2025 10:03 #334762
by Retrofit
Carousel don t stop when estop is pushed was created by Retrofit
Hello to everybody
I retrofited two mills , one is complet functional , it work fine , Cincinna Milacro , and other one it is on demand , Leadwell VMC40.
The first is with 7i92+7177+7i84 Mesa Cards , and the second with cards from Yurtaev.com (mithsubishi) , pci card.
On the second mill , when I try to configurate the carousel for homing ,carousel starts moving , but when I push the estop to stop the rotate , don t stop !, even from desktop estop or power btn . So, I try this for the first one mill to check it ,and , unfortunately is the same issue.
The same is when M6 Txx is requared from MDI , don t stop when estop is pushed , on both of mills.
The carousel have geneva mechanism , both of them with home pin and index pin .The configuration is from examples that are in Probe basic files(M13)
Any advice for eliminate the issue ?
Thanx in advance
Thanx in advance
- Retrofit
11 Sep 2025 06:36 #334808
by Retrofit
Replied by Retrofit on topic Carousel don t stop when estop is pushed
Hello langdons
What means 'does linuxcnc display ESTOP?"
I refear to the Estop button from display (Probe basic UI) , when I say even from desktop estop button , or power buton.
- Thank you received: 5315
11 Sep 2025 14:00 #334827
Replied by PCW on topic Carousel don t stop when estop is pushed
You likely need to condition the carousel control pins with
motion.motion-enabled or similar.
Posting your hal file or at least the carousel portion would
allow a more specific suggestion.
The following user(s) said Thank You: Lcvette
- Lcvette
- Thank you received: 782
12 Sep 2025 14:06 #334885
by Lcvette
Replied by Lcvette on topic Carousel don t stop when estop is pushed
As PCW mentioned those I/O should have some conditional motion safeties in hal, also anything critical that needs to stop immediately should also be wired to a power disconnect contactor to ensure absolute motion halting in the event of a estop. for mine my mushroom button halts both linuxcnc and all drives and motors. for the screen estop its just halting in software. this way i only press the danger mushroom if it is imperative everything must cease STAT!
- Retrofit
13 Sep 2025 14:17 #334925
by Retrofit
Thanx for all the advices , PCW , Lcvette , Langdons , I already start to rewire the 24 V needed for the pins from a estop controled wiring , this is a good solution .
I will atached the hal files that included the carousel movement.
- Lcvette
26 Sep 2025 16:07 #335460
by Lcvette
were you able to get this resolved?
Moderators: KCJ, Lcvette
Time to create page: 0.429 seconds
