Probebasic tool length calculation
08 Nov 2025 17:44 #338096 by tsaG
I am using my ATC spindle with a tool setter. Z0 is at the top of the machine.
The Spindle Nose is probed at -202mm (so, entered as 202mm in the GUI).
When probing the tool (measured with a caliper to be around 57mm), it triggers at around -145mm. However, the GUI reports it as 120mm Long. Is there something I can tweak?
08 Nov 2025 21:50 #338099 by Lcvette
Replied by Lcvette on topic Probebasic tool length calculation
Songs like you still have a tool length offset active while probing
09 Nov 2025 15:58 #338126 by tsaG
Replied by tsaG on topic Probebasic tool length calculation
Hmm. Strange. Could you remind me on how to change this?
All I did was Start Linux CNC, Power the machine, home it, insert the tool (either via rack ATC or manual) and probe the length.
BTW: In which repo would I commit changes to? I saw that there are two Github repos, but ( I assume its yours) is rather old whereas the changes in kcjengr is only half a year old.
09 Nov 2025 17:00 #338128 by Lcvette
Just remove any current tool length offset.
Kcjengr is correct.
10 Nov 2025 14:42 #338154 by tsaG
Okay, with "remove any current tool length offset" you mean to remove the offset saved in the tool table? Shouldn't the tool probing overwrite this offset?
11 Nov 2025 10:45 #338196 by Lcvette
G49, did you modify your tool setter macro? If not I would check that your var file and pb version are all correctly aligned and the parameters are storing in the var file.
12 Nov 2025 08:45 #338250 by tsaG
No, I did not modify it.
I think I saw something in the Offset tabs but I am unable to fully understand and get rid of it. I did some tests but I was not able to remove the offset.
I mean, the mill works so far as every tool has the same huge offset but I still would like to understand why and where it comes from. I did a video that could help, but, to be honest, I do not know what to do....
I attached my var file (renamed as ini as the forum apparently doesn't allow uploading var files) as well as the machine config.
I also created a video of clicking around in the menu. cloud.bihnairy.de/s/eDjYwNrbX8apHQF
12 Nov 2025 10:57 #338258 by Lcvette
where is your z home position set?
12 Nov 2025 11:11 #338259 by Lcvette
ah are you using the tool setter page to set the spindle zero with the probe spindle zero button?
12 Nov 2025 11:49 #338266 by Lcvette
ok i think i found a bug dealing with pocket in the tool table causing some odd behavior. let me dig into it some and see what is happening.
Moderators: KCJ, Lcvette
Time to create page: 0.096 seconds
