Probebasic tool length calculation
- tsaG
- Thank you received: 4
08 Nov 2025 17:44 #338096
by tsaG
Probebasic tool length calculation was created by tsaG
I am using my ATC spindle with a tool setter. Z0 is at the top of the machine.
The Spindle Nose is probed at -202mm (so, entered as 202mm in the GUI).
When probing the tool (measured with a caliper to be around 57mm), it triggers at around -145mm. However, the GUI reports it as 120mm Long. Is there something I can tweak?
- Lcvette
- Thank you received: 784
08 Nov 2025 21:50 #338099
by Lcvette
Replied by Lcvette on topic Probebasic tool length calculation
Songs like you still have a tool length offset active while probing
- tsaG
09 Nov 2025 15:58 #338126
by tsaG
Replied by tsaG on topic Probebasic tool length calculation
Hmm. Strange. Could you remind me on how to change this?
All I did was Start Linux CNC, Power the machine, home it, insert the tool (either via rack ATC or manual) and probe the length.
BTW: In which repo would I commit changes to? I saw that there are two Github repos, but ( I assume its yours) is rather old whereas the changes in kcjengr is only half a year old.
- Lcvette
09 Nov 2025 17:00 #338128
by Lcvette
Just remove any current tool length offset.
Kcjengr is correct.
Kcjengr is correct.
- tsaG
10 Nov 2025 14:42 #338154
by tsaG
Okay, with "remove any current tool length offset" you mean to remove the offset saved in the tool table? Shouldn't the tool probing overwrite this offset?
- Lcvette
11 Nov 2025 10:45 #338196
by Lcvette
G49, did you modify your tool setter macro? If not I would check that your var file and pb version are all correctly aligned and the parameters are storing in the var file.
- tsaG
12 Nov 2025 08:45 #338250
by tsaG
No, I did not modify it.
I think I saw something in the Offset tabs but I am unable to fully understand and get rid of it. I did some tests but I was not able to remove the offset.
I mean, the mill works so far as every tool has the same huge offset but I still would like to understand why and where it comes from. I did a video that could help, but, to be honest, I do not know what to do....
I attached my var file (renamed as ini as the forum apparently doesn't allow uploading var files) as well as the machine config.
I also created a video of clicking around in the menu. cloud.bihnairy.de/s/eDjYwNrbX8apHQF
- Lcvette
12 Nov 2025 10:57 #338258
by Lcvette
where is your z home position set?
- Lcvette
12 Nov 2025 11:11 #338259
by Lcvette
ah are you using the tool setter page to set the spindle zero with the probe spindle zero button?
- Lcvette
12 Nov 2025 11:49 #338266
by Lcvette
ok i think i found a bug dealing with pocket in the tool table causing some odd behavior. let me dig into it some and see what is happening.
Moderators: KCJ, Lcvette
