How to disable buttons in Probe Basic
11 Nov 2025 22:41 #338235 by nwallace
How to disable buttons in Probe Basic was created by nwallace
I am trying to figure out a clean way to disable some buttons in the Probe Basic UI. We currently use an old version on our machine with a few buttons disabled. With the older version, it was as simple as adding something like "self.tool_diameter_probe_Btn.setEnabled(False)" to a properly setup custom_probebasic.py file in the config folder. On the new version installed via apt, this does not work to disable buttons. Our machine gets used by people who may or may not be trained on all aspects of it so I would like to limit some things. I am happy to go and comment out things in order to use buttons when I am working on the machine. Is there a "right" way to do this?
12 Nov 2025 10:16 #338255 by nwallace
Replied by nwallace on topic How to disable buttons in Probe Basic
I do not mess with working configs. Currently testing on a VM. I'm trying to solve a problem with the old interface locking up after probing.
Your comment is supremely unhelpful. If I was someone who had just broken a working install and I was desperate to get it working again, maybe making them feel dumb is the wrong approach.
Not sure what version of probe basic the old one is but I am testing on the latest available installed via apt based on the documentation.
12 Nov 2025 13:23 #338275 by nwallace
A reinstall unfortunately does not solve the issue. I am also not sure that this is a new problem. It looks like the running version is probe-basic_0.5.3-216. We never tried using the probing part of the interface until a few days ago. After the probing routine completes, the ui stays in the busy state indefinitely if I had it set to update the WCO. If it is only set to measure, it works fine. I can find no significant differences between the old and the updated probing routines. Also, probing with my own custom routines works fine. It is only when I click a probing routine on the probing tab with it set to update the WCO that it locks up. If I comment out the G10 line, the ui does not stay locked. I have tried running linuxcnc from the terminal to see if there is any debug output but no luck there either.
I figured that support from the people who make it for what appears to be a bug in a version from 2023 would be a long shot. It is from before installing from apt was even an option. There are also a few modifications I no longer have to do because they have become features. I have not connected the new version to the machine to test if probing behaves the same way yet. Wanted to make sure I could get everything to behave the way we have trained people. I have a little mini pc set aside to for that once I get a copy of the config modified for our machine.
Appreciate that it can be tiresome to see the same stuff repeatedly. Everyone is at a different point in their journey of learning.
12 Nov 2025 13:39 #338278 by Lcvette
Replied by Lcvette on topic How to disable buttons in Probe Basic
I'm guessing your previous install was a version prior to Python 3. The py2 versions worked with a pip install as run in place where apt installs in root. Your custom py file should still work though. It may be a py2 file needed updating to py3?
12 Nov 2025 14:46 #338282 by nwallace
It is definitely a python 3 version. If I remember correctly, it was shortly after the pip install method stopped working and the install documentation was in a little bit of flux at the time. The new version I am working on does not throw an error when I try to disable a button, It just does nothing.
I will preface this next part by saying that I have just enough skill in reading and understanding code to get into trouble. I haven't used AI stuff because I don't have the skill to double check it. I found when digging through the source that sub call buttons reference issue_mdi.bindOk which references some stuff in the status plugin.
With guess and check I have found that on SubCallButtons I can do this:
STATUS.homed.onValueChanged(lambda: self.probe_spindle_nose_subcallbutton.setEnabled(False))
With this added to the top section of the file:
STATUS = getPlugin('status')
I don't know if this is a good way to do it but it does disable the button.
16 Nov 2025 19:54 #338557 by Lcvette
Sure that's fine, it's basically using widget rules in your Python custom file which should be fine. Just adding a conditional for the button state. If that works roll with it! I don't see an issue with that.
17 Nov 2025 13:59 #338570 by nwallace
Unfortunately, this does not work on the actual machine. It worked on the sim on a VM but does not behave the same on the physical machine. I can't figure out why. I also can't figure out why just disabling with 'self.probe_spindle_nose_subcallbutton.setEnabled(False)' doesn't work either. Any pointers? I am out of things to look at that I can vaguely understand.
17 Nov 2025 17:59 - 17 Nov 2025 18:01 #338591 by nwallace
I should also add that the "STATUS.homed.onVal..." method does work on VCPSettingsPushButton type buttons but not on SubCallButton types. Setting the .setEnabled(False) property of either does not work directly.
Edit: In good news, the new version seems to have solved my issue with the UI locking up after using a probing routine. Probing is working great now.
Last edit: 17 Nov 2025 18:01 by nwallace. Reason: Added info about new version fixing probing
17 Nov 2025 21:44 #338602 by Lcvette
Only widgets with VCP in the have rules availability. Which is why you cannot use the native rules format on some of the widgets.  You should still be able to enable with full Python code and a tracking method set on a timer. But that's gets kind of convoluted.  I'm not sure what your best course of action would be except maybe to customize the ui itself with a lock of some sort.  Billy hiddleson some things like this, he is active on the basic Facebook group, may be good to ask him there as he does very similar things to you requirement for his maker space machines for safety.
18 Nov 2025 17:18 #338665 by nwallace
Thanks for the info. I sent a request to join the probe basic facebook group. It appears to have gone private in a new group that is members only.
Moderators: KCJ, Lcvette
Time to create page: 0.280 seconds
