Probe Error causes Jog lockout
22 Dec 2025 21:24 #340410 by Thllll
Probe Error causes Jog lockout was created by Thllll
2.9.4, Probe Basic
Probing failure either a g38.2 or g38.3 locks out the jog,
Estop cycle , machine power cycle , probe on or off, homing, locks out jogging in all directions. Any way to reset this without restarting Linuxcnc?
28 Dec 2025 14:28 #340629 by andypugh
Replied by andypugh on topic Probe Error causes Jog lockout
I don't see this in 2.9.7 with Axis (I don't have a Probe Basic setup to test with)
Can you see if you see the same issue in Axis with one of the sim configs? (This won't affect your real config)
28 Dec 2025 15:11 #340631 by Thllll
Replied by Thllll on topic Probe Error causes Jog lockout
Axis works fine, QT dragon also works fine. Its just Probe Basic
31 Dec 2025 10:24 #340780 by Lcvette
Replied by Lcvette on topic Probe Error causes Jog lockout
are you changing back to manual or mdi mode and is the probing routine your running completing and changing back after being in auto mode?
31 Dec 2025 12:55 #340789 by Thllll
It wont let you change the mode, its gets locked out. I gave up on getting probe basic to work
01 Jan 2026 13:42 #340851 by Lcvette
when you say locks out, were you referring to keyboard, on screen buttons, or both?
01 Jan 2026 13:50 #340852 by Lcvette
if you still have probe basic installed, would you mind running a test in the simulation? I am running a sim test here and cannot reproduce the error using the on screen probing buttons. i can probe a point in space and immediately jog afterwards using both the keyboard and on screen buttons. so its hard for me to discover why your install is not responding the same. but if you test the sim and the problem does not exist then it would be something in your configuration most likely.
01 Jan 2026 13:56 #340853 by Lcvette
video showing it functioning in sim and how to test:
load tool 99 probe tool, move probe tip somewhere clear in the work envelope, use inside corners probe page and select a single move probe routine, trigger the probe by clicking the probe graphics probe tip. try jogging to see if sim repsonds correctly.
02 Jan 2026 09:01 #340886 by Thllll
I am unable to reproduce the error on the sim because I needed to trigger the probe while it was going to home or the starting location to start probing. This would cause a G38.2 error then the lockout would start. I ran a debug and returned a [Error] from a specific routine. I should have grabbed a screenshot.. I noticed a difference in the sim subroutines folder vs the subroutines folder I got from the github. I replaced all the files and lockout is no longer accruing
04 Jan 2026 08:55 #340967 by Lcvette
ok great!
Moderators: KCJ, Lcvette
Time to create page: 0.252 seconds
