Some problems with probe basic lathe
8 months 2 weeks ago #342954 by Lcvette
It is not specific to probe basic, but linuxcnc by andypugh, perhaps search kathe macros, i think there is a big thread on it and how to use and you can check if the macros are correct
8 months 2 weeks ago - 8 months 2 weeks ago #342956 by Ismacr63
I’ve been reading through AndyPugh thread, but honestly I still have no idea how to get it working in Probe Basic Lathe.
Last edit: 8 months 2 weeks ago by Ismacr63.
8 months 2 weeks ago - 8 months 2 weeks ago #342964 by Ismacr63
I’ve updated AndyPugh macros to the latest version, and now it seems to work, but it shows the tool change tab and doesn’t go any further.
8 months 2 weeks ago #342970 by Lcvette
You maybe could check the lathe macros uo files using editvcp and fine the lathe macros in the probe basic widgets directory and verify the parsee widhet entry names correspond correctly with the macros being used. From a glance it appears they may not be the same.
github.com/kcjengr/probe_basic/tree/main...dgets/conversational
You need to make sure those variables are get ng from the ui to the subroutine at the top.
8 months 2 weeks ago #343016 by Ismacr63
I’ve tried changing the field names in Turning using Qt Designer so they match the macros, but without success. I’m not exactly sure if what I tried makes any sense, since I don’t have experience with this.I’ve looked at the files in the link, but are they for Probe Basic Mill? This is a bit beyond me because I don’t really have the necessary knowledge…I also saw a post on the Facebook page about an update to the lathe conversational section. Does anyone know when that update will be released?
8 months 2 weeks ago #343020 by Lcvette
dont change the ui names, modify the macros otherwise on an update you will be overwritten while macros in your config folder for machine are not
The following user(s) said Thank You: Ismacr63
Moderators: KCJ, Lcvette
Time to create page: 0.497 seconds
