- User Interfaces
- Other User Interfaces
- QtPyVCP
- 30 Second timeout before opening and E-Stop button not clicking...
- susan-parker
- Thank you received: 6
21 Mar 2026 17:34 #344581
by susan-parker
30 Second timeout before opening and E-Stop button not clicking... was created by susan-parker
Trying to setup Probe Basic Lathe for use with an EMCO Compact 5 CNC lathe with my own electronics.
After the splash screen there is about a 30 second delay before the main GUI appears.
All looks okay, the tabs work but the E-Stop won't click...
Note: In AXIS the E-Stop is correctly asserted for the 7i96s, and the power button works to enable a 7i96s output.
I think it is a python thing, but don't know where to look.
- susan-parker
22 Mar 2026 15:26 #344607
by susan-parker
Replied by susan-parker on topic 30 Second timeout before opening and E-Stop button not clicking...
$ qtpyvcp -i
QtPyVCP Info
Version: 5.1.0+14.gba8f741e
LinuxCNC Info
Version: 2.9.8
Qt Info
Qt Version: 5.15.8
Qt API: PyQt5
Qt API Version: 5.15.9
System Info
Description: Debian GNU/Linux 12 (bookworm)
Kernel: 6.1.0-30-rt-amd64
Version: #1 SMP PREEMPT_RT Debian 6.1.124-1 (2025-01-12)
Ram: 7 GB
CPU Info
Vendor ID: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
Architecture:
Physical Cores: 4
Logical Cores: 8
QtPyVCP Info
LinuxCNC Info
Version: 2.9.8
Qt Info
Qt Version: 5.15.8
Qt API: PyQt5
System Info
Ram: 7 GB
CPU Info
Architecture:
Physical Cores: 4
Logical Cores: 8
- susan-parker
22 Mar 2026 15:54 #344610
by susan-parker
The last error message (whilst I was sorting out the copying of stuff into the .ini file - not getting any at present) had this:
Traceback File "/usr/lib/python3/dist-packages/qtpyvcp/plugins/notifications.py", in timerEvent error = self.error_channel.poll() ^^^^^^^^^^^^^^^^^^^^^^^^^ linuxcnc.error: Error buffer invalid
... not sure if any relevance.
- Lcvette
- Thank you received: 784
25 Mar 2026 00:46 #344691
by Lcvette
Replied by Lcvette on topic 30 Second timeout before opening and E-Stop button not clicking...
How about the SIM, does the SIM start and work as expected? If so it's almost certainly a config setting issue.
This sounds like maybe an estop conflict. Or perhaps a post gui hal file issue.
The following user(s) said Thank You: susan-parker
- susan-parker
26 Mar 2026 20:58 #344800
by susan-parker
Probe in Sim works okay... now comparing the various files.
Thanks for the suggestion.
The following user(s) said Thank You: Lcvette
- Lcvette
28 Mar 2026 02:29 #344862
by Lcvette
Find the culprit?
- susan-parker
30 Mar 2026 13:25 #344950
by susan-parker
No, sadly not!
I tried various other things too, but nope.
I am going back to do a completely new install from scratch of Linux, etc. which requires a SSD shuffle between computers.
- Lcvette
30 Mar 2026 16:39 #344961
by Lcvette
if the sim opens and works (ie.. press estop, press power, press ref all and it works) its not an installation issue. the problem would be pointing to your machine (milling machine) configuration problem, maybe post your configuration to github and share the link here so we can have a look and maybe help get you sorted out. having the configuration on github is nice because you will always have quick access to it for reference or troubleshooting even when not at your machine pc.
- susan-parker
30 Mar 2026 19:48 #344969
by susan-parker
Okay, my two setups are here:
github.com/TriodeGirl/LinuxCNC
The AXIS one works, the Probe_Basic is the issue.
I am using a MESA 7i96s board set at 10.10.10.10
I have E-Stop enabled, and am supplying a suitable active signal to the pin input. This works under AXIS.
Many thanks.
Many thanks.
- Lcvette
31 Mar 2026 03:00 #344981
by Lcvette
first thign i see is you ar emissing the postgui hal file that is required. you need to uncomment the ini for that line and copy over the probe basic post guiio hal file as is stated in the docs.
it looks like you may have missed a few steps, go beack through the machine config section in the docs really carefully and make sure you have done all of the steps accordingly and i think you will find things will work as expected.
kcjengr.github.io/probe_basic/machine_config.html
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 0.143 seconds
