Probe Basic and XHC-WHB04B-6 jogging issue
  • spacemanspiffee
  • spacemanspiffee's Avatar Topic Author
  • Junior Member
  • Junior Member
09 Apr 2026 00:14 - 09 Apr 2026 00:17 #345346 by spacemanspiffee
Probe Basic and XHC-WHB04B-6 jogging issue was created by spacemanspiffee
Hi all, I'm working on moving from an older (Linuxcnc 2.8) Axis config to a Probe Basic config after getting a new spindle for my router.
I have successfully gotten the basics working and have even gotten the ATC functions mostly where I want them. (Huge thanks for the the starting point that is the Probe Basic screen set and all the macros)
I am running into trouble integrating my XHC-WHB04B-6 pendant. It works just how I want it to in the old Axis configuration, and in fact that configuration runs just fine under Linuxcnc 2.9 and the pendant works in that config.
However, in Probe Basic the pendant produces stuttery motion when jogging both in step mode and in continuous mode. It also will not register all pulses or clicks of the jog wheel when the wheel is spun quickly. If I slowly click the wheel in step mode (say 1 click per second) I get each step translated into machine motion, but if I quickly spin the jog wheel, I will only get a small fraction of the wheel clicks actually translating into machine motion.
General info:
-  What Linux OS being used including kernel type?
> Debian GNU/Linux 12 (bookworm)
> Kernel version: 6.1.0-44-rt-amd64
-  What version of Linuxcnc is installed?
> 2.9.8
-  What version of QtPyVCP and Probe Basic is installed?
> Probe Basic version: 0.6.6
-  How did you install Probe Basic? Quickstart guide? Dev Guide?
> Probe Basic APT stable install following the guide here: kcjengr.github.io/probe_basic/index.html
-  Have you gone through your ini and hal files and compared to the sim config files to make any changes needed?
> Yes, Probe Basic is functioning, just the integration with the pendant is giving me headaches
-  Have you added all of the necessary files in your config folder that probe basic needs to run?
> Yes
I attached the hal files ini files and pendant hal files for the two configs. (note i renamed the pendant.hal file for the Odroid config so that there were not two of the same file name)
Please take a look and let me know if more info will make the problem easier to diagnose.
Thanks!
Last edit: 09 Apr 2026 00:17 by spacemanspiffee. Reason: adding attachments
14 Apr 2026 01:21 #345513 by Lcvette
Replied by Lcvette on topic Probe Basic and XHC-WHB04B-6 jogging issue
You may have a timer issue, I know others had conflict with the timer and hbo4 pregnant, I would investigate that.
Aside from that I'm not sure what would cause that except maybe a setting for the pregnant specific that may require a change?
Hopefully someone else can come in with knowledge on it. My wired jog pendant uses velocity mode when the speed is to fast for motion and the pulses begin to stack up, this stupid a runaway axis condition.
The following user(s) said Thank You: spacemanspiffee
  • spacemanspiffee
  • Junior Member
  • Junior Member
14 Apr 2026 03:49 #345516 by spacemanspiffee
Replied by spacemanspiffee on topic Probe Basic and XHC-WHB04B-6 jogging issue
Update on my situation.
I was able to solve my jog pendant issues.
There were two changes I made:
1. halui signals:
Probe Basic
# ---HALUI signals---
net axis-select-x halui.axis.x.select
# net jog-x-pos halui.axis.x.plus
# net jog-x-neg halui.axis.x.minus
# net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
# net jog-y-pos halui.axis.y.plus
# net jog-y-neg halui.axis.y.minus
# net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
# net jog-z-pos halui.axis.z.plus
# net jog-z-neg halui.axis.z.minus
# net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
# net jog-selected-pos halui.axis.selected.plus
# net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
# net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdiAxis# ---HALUI signals---
#net axis-select-x halui.axis.x.select
#net x-is-homed halui.joint.0.is-homed
#net axis-select-y halui.axis.y.select
#net y-is-homed halui.joint.1.is-homed
#net axis-select-z halui.axis.z.select
#net z-is-homed halui.joint.2.is-homed
#net spindle-manual-cw halui.spindle.0.forward
#net spindle-manual-ccw halui.spindle.0.reverse
#net spindle-manual-stop halui.spindle.0.stop
#net machine-is-on halui.machine.is-on
#net MDI-mode halui.mode.is-mdi
For some reason I had ended up with the exact opposite lines commented between the new probe basic and the old axis configs (probably had used a toggle comment command in vs code accidentally). I swapped the commenting in the probe basic hal file to match the old axis file.
2. pendant.hal and pin conflicts
I had some pin conflicts between pendant.hal and the postgui hal that probe basic uses. I had originally changed them in the pendant.hal file to preserve probe basic postgui hal file. Now, I am using the pendant.hal file that worked with the old axis config and I modified the conflicting pins in the post gui hal file from probe basic.
Between those two changes, the pendant is now functioning just how it was on the old axis configuration.
So now I have a functioning pendant and a functioning ATC using probe basic as the UI.
Next to get my ATC rack made and get my probe working.
The following user(s) said Thank You: Lcvette
14 Apr 2026 15:35 - 14 Apr 2026 15:35 #345543 by Lcvette
That's great news, glad you got it sorted out!
Last edit: 14 Apr 2026 15:35 by Lcvette.
Moderators: KCJ, Lcvette
Time to create page: 0.234 seconds
