Probe basic error
- ncf250sd
15 Sep 2026 20:06 #349667
by ncf250sd
Probe basic error was created by ncf250sd
I just updated to the latest probe basic (Probe Basic APT Stable Install Bookworm 12). I do not use an ATC. Everything is working as it was before the update except I get this error (Error Named parameter #<number_of_pockets> not defined ) when trying to load a tool utilizing the Tool Change Panel (load tool).If I load a tool from the main screen it works fine. I can even use the Tool change panel to unload the tool. I have looked through my ini file and cannot see anything out of place. Any suggestions on where to start looking would be appreciated.
- ncf250sd
16 Sep 2026 10:08 #349679
by ncf250sd
Replied by ncf250sd on topic Probe basic error
Fixed. The ini file was missing this.
[ATC]
# Number of pockets in the carousel (set to 0 or 1
I did not see that referenced in any of the installation manual documents. I may have just missed it.
[ATC]
The following user(s) said Thank You: tommylight, Lcvette
- Lcvette
- Thank you received: 784
16 Sep 2026 13:42 #349682
by Lcvette
Replied by Lcvette on topic Probe basic error
thanks for pointing that out, i have updated the configuration documents to reflect the missing config items, sorry about that, got missed somehow.. should be up shortly!
- ncf250sd
16 Sep 2026 16:32 #349689
by ncf250sd
My small contribution compared to all the help I’ve received.
Moderators: KCJ, Lcvette
Time to create page: 0.224 seconds
