Keybind with arguments
- phillc54
- Thank you received: 2100
22 Jan 2020 03:49 #155414
by phillc54
Keybind with arguments was created by phillc54
Is it possible to pass arguments to a keybind function.
Rather than having multiple functions for say 0~8 I would like to call one function and pass the number as the argument.
- Thank you received: 2181
22 Jan 2020 04:16 #155416
Replied by cmorley on topic Keybind with arguments
Not currently unless you code keybinding yourself, but I think I could add that to qtvcp's stock key binding library.
I'm thinking you call a function to register a dict of keys:values and a function name.
something like :
klist ={'Key_0':0,'Key_1':1}
KEYBIND.add_function_keylist(klist, 'on_keycall_custom')
and the function would be:
def on_keycall_custom(self,event,state,shift,cntrl,value):
Is that sorta what you are thinking?
Chris
something like :
Chris
- phillc54
22 Jan 2020 04:33 #155418
by phillc54
Replied by phillc54 on topic Keybind with arguments
TBH I hadn't thought too much on the how, I was just hoping for a way to save a bit of repetition.
I think what you proposed would work fine.
I ditched the old QtVCP screen I did for PlasmaC, it was much too cluttered and I have started a modified version of QtAxis although now I have seen QtDragon...
22 Jan 2020 05:31 #155420
ok pushed some keybinding code and qt_cnc (the default screen) showcases it.
if you run default in a terminal and press f9 f10 or f11 it will print a message in the terminal - all from one function.
The code to add to handler file:
(the value can be any python object here we used strings and an integer)
KEYBIND.add_call('Key_F9','on_keycall_custom','f9 pressed tesst')
KEYBIND.add_call('Key_F10','on_keycall_custom',10)
KEYBIND.add_call('Key_F11','on_keycall_custom','f11 pressed test')
and the function:
if state:
print 'custom keycall function value: ',value
and the function:
if state:
- phillc54
22 Jan 2020 05:54 #155421
by phillc54
Thanks Chris, that was quick, looks ideal.
I won't get much time for a couple of days but when I do I'll report back.
- phillc54
23 Jan 2020 18:34 #155604
by phillc54
That update does exactly what I was after, thanks again.
24 Jan 2020 01:28 #155635
It was a great idea!
Chris
Chris
Time to create page: 0.774 seconds
