Gcode Graphics
6 years 6 months ago #162648 by cmorley
Replied by cmorley on topic Gcode Graphics
In AXIS try selecting alpha_blend in the 'View' drop down list.
It made quite a difference.
If that's an improvement I can easily add that to qtvcp.
Chris
6 years 6 months ago - 6 years 6 months ago #162649 by hottabich
Replied by hottabich on topic Gcode Graphics
Super! Can this be added to Qtvcp?
With respect Jura.
Last edit: 6 years 6 months ago by hottabich.
6 years 6 months ago #162650 by cmorley
yes the code is there - it just needs to be turned on.
You did a custom screen for qtdragin didn't you?
add:
self.w.gcodegraphics.program_alpha = True
to init_widgets(self); function
I'll see about making it easier in the future.
6 years 6 months ago #162661 by hottabich
Thank you so much! The picture is beautiful, but it cannot be moved in the window.
The file is being reloaded. In Qtpyvcp, I freely move the picture.
6 years 6 months ago #162662 by cmorley
yes it stalls because it think you selected a line to highlight and the program is huge to search through.
We can disable this with some more handler code:
self.w.gcodegraphics.program_alpha = True self.w.gcodegraphics.select_fire = self.select_fire def select_fire(self): return
You won't be able to select gcode lines in the screen though
Ini the mean time i will try to add background searching so it doesn't block.
Chris
6 years 6 months ago - 6 years 6 months ago #162664 by hottabich
You are the best on this forum! It works so well! You have a very hard job, thanks for taking the time to help me.
Time to create page: 0.302 seconds
