Gcode Graphics
- hottabich
- Thank you received: 96
04 Apr 2020 00:24 #162638
by hottabich
Gcode Graphics was created by hottabich
Hello! Please tell me how to increase the resolution in Gcode Graphics or integrate
GcodeBackplot from Qtpyvcp? For comparison, I give screenshots.
- Thank you received: 2181
04 Apr 2020 00:59 #162639
Replied by cmorley on topic Gcode Graphics
I don't know what the problem Gcode graphics. Could you post a sample prorgram that shows the problem so i can test? Even a partial (if you are worried about giving away a gcode program)
As far as adding qtpyvcp's backplot - that would be nice it uses different technology.
Unfortunately it requires newer libraries then some of our distributions supply.
I will look into seeing if we could suport both technologies in the future.
Chris
Chris
04 Apr 2020 01:23 #162640
there is an INI setting available for AXIS called ARCDIVISION that may make a difference.
linuxcnc.org/docs/2.8/html/config/ini-co...tml#_display_section
Looks like it is only use in AXIS.
Could you try your program in AXIS and if the setting makes a difference i can try to incorporate that code difference into qtvcp
Chris
Chris
04 Apr 2020 01:24 #162641
64 is the default setting, I would guess higher is better accuracy
Chris
Chris
- hottabich
04 Apr 2020 02:00 - 04 Apr 2020 02:13 #162644
by hottabich
Replied by hottabich on topic Gcode Graphics
Thank you for attention! In AXIS, visualization is like in Qtvcp. I just can't go from MACH3 to
Linuxcnc. Qtvcp has poor visualization, and jogIncremental is not working properly in Qtpyvcp.
Last edit: 04 Apr 2020 02:13 by hottabich.
- bbsr_5a
- Thank you received: 106
04 Apr 2020 02:04 #162645
by bbsr_5a
Replied by bbsr_5a on topic Gcode Graphics
this are very tight lines if thel ines are more spaced as of the cutter it looks like rougher
but this is normal behavior it does not show the Part only the millinglines
if yoiu zoom in it also gets rougher to thel ines
use CAMOTICS to show the outcome of g-code
and visual in Blender
04 Apr 2020 02:48 #162648
In AXIS try selecting alpha_blend in the 'View' drop down list.
It made quite a difference.
If that's an improvement I can easily add that to qtvcp.
Chris
Chris
- hottabich
04 Apr 2020 03:14 - 04 Apr 2020 03:17 #162649
by hottabich
Super! Can this be added to Qtvcp?
With respect Jura.
With respect Jura.
Last edit: 04 Apr 2020 03:17 by hottabich.
04 Apr 2020 03:29 #162650
yes the code is there - it just needs to be turned on.
You did a custom screen for qtdragin didn't you?
add:
self.w.gcodegraphics.program_alpha = True
to init_widgets(self); function
I'll see about making it easier in the future.
add:
- hottabich
04 Apr 2020 05:05 #162661
by hottabich
Thank you so much! The picture is beautiful, but it cannot be moved in the window.
The file is being reloaded. In Qtpyvcp, I freely move the picture.
Time to create page: 0.805 seconds
