Gcode Graphics
04 Mar 2021 13:54 #201036 by tacklem60
Replied by tacklem60 on topic Gcode Graphics
Thanks Chris!
I am using a Buster RTAI kernel of LinuxCNC so I’m guessing these updates won’t push to my machine? Is there a way I can make the changes needed on my end?
04 Mar 2021 15:04 #201044 by cmorley
Replied by cmorley on topic Gcode Graphics
if you used the buildbot to install you should be able to update linuxcnc .. when the buildbot puts out the next build.
other wise you would need to replace the qtdragon.ui and qtdragon_handler.py file with the new ones.
Chris
Time to create page: 0.677 seconds
