Gcode Graphics
- Thank you received: 2181
04 Apr 2020 10:17 #162662
Replied by cmorley on topic Gcode Graphics
yes it stalls because it think you selected a line to highlight and the program is huge to search through.
We can disable this with some more handler code:
You won't be able to select gcode lines in the screen though
Ini the mean time i will try to add background searching so it doesn't block.
Chris
self.w.gcodegraphics.program_alpha = True
self.w.gcodegraphics.select_fire = self.select_fire
def select_fire(self):
returnIni the mean time i will try to add background searching so it doesn't block.
Chris
- hottabich
- Thank you received: 96
04 Apr 2020 10:31 - 04 Apr 2020 10:32 #162664
by hottabich
Replied by hottabich on topic Gcode Graphics
You are the best on this forum! It works so well! You have a very hard job, thanks for taking the time to help me.
Last edit: 04 Apr 2020 10:32 by hottabich.
04 Apr 2020 10:35 #162665
Добро пожаловать. Спасибо за ответ!
(Google translate)
(Google translate)
- tacklem60
04 Mar 2021 00:01 #200963
by tacklem60
Replied by tacklem60 on topic Gcode Graphics
So I tried entering this into my handler file. It worked great, a huge noticable change in the resolution of the GCode and I was also having issues with the GUI freezing (usually for about 5-10 seconds) when I clicked and dragged to pan around the gcode graphics display on larger files. Clicking on a line of gcode is never something that I have used in my workflow so I would be more than happy to get rid of it.
After pasting that code into my handler file, the entire GUI seems to work great, crystal clear graphics and no freezing when panning on larger files. However, somehow by adding those few lines of code it renders my cycle start button useless. Nothing at all happens when I try hitting it. Any ideas at what could be causing it?
04 Mar 2021 02:20 #200983
What screen are you using?
no i can't see how that affects the cycle start.
- tacklem60
04 Mar 2021 02:38 #200984
by tacklem60
I am using QTDragon. I just did a little messing around. The edits I am making are to the section of the handler named
def init_widgets(self):
When adding only the line "self.w.gcodegraphics.program_alpha = True" to the bottom of that section of the code, the graphics display has a very noticeable resolution change. Like the other user stated though, if you try to pan at all with that enabled, it will freeze the UI while it seemingly searches for which line of code you clicked on (even if you clicked on blank space in the graphics). Without the alpha turned on, that freeze is roughly 10 seconds for the gcode I am currently using to test it and with it enabled, the freeze lasted >60seconds before the UI became responsive again.
With the full text here below that you posted in the previous response, the UI responds wonderful, but the cycle start no longer works.
return
return
04 Mar 2021 02:50 #200985
alpha mode should already be available in the settings page.
also 'inhibit mouse selection' to stop the pause.
Chris
Chris
- tacklem60
04 Mar 2021 03:04 #200986
by tacklem60
Ok, this might take the problem a layer deeper. I have always known about those settings but they never seemed to have any effect.
I removed the line of code about alpha always = True and found the following.
Those buttons absolutely do work and they will turn on and off alpha display as well as inhibit mouse selection. Unfortunately, that only works if I cycle the option off then back on again when I start the UI. If I leave those boxes checked (or either one individually), when I restart the UI and check settings, they are still selected but they function as if they are turned off. If I uncheck the option and turn it back on again, I then get the desired effect again and it seems to remain active until I restart the UI.
Joe
Joe
04 Mar 2021 03:19 #200988
ok
I'll look into that
I'll look into that
04 Mar 2021 18:45 #201034
Ok I hope i got this fixed properly now in qtdragon and qtdragon_hd (master branch)
Time to create page: 0.133 seconds
