qtvcp interface debugging with eclipse
07 Apr 2020 16:17 #163076 by ioiotutu
qtvcp interface debugging with eclipse was created by ioiotutu
I'm writing a special interface using qtvcp & opencv and i need a debug ambient to understand varius code bugs. I usaully use Eclipse with pyDev for debugging my python module.
Is it possible with eclipse debugging a qtvcp project?
Has someone test eclipse with qtvcp?
Thanks,
Michele
07 Apr 2020 23:54 #163125 by cmorley
Replied by cmorley on topic qtvcp interface debugging with eclipse
sorry I don't use a debugger or an IDE.
Some times I use pythons debug module but I'm sure thats not what you want.
On another note - qtvcp has a camview widget that uses opencv for manual machine alignment. I've seen some interesting things with opencv like finding holes and reading dials..
Hope to see what you get up to.
Chris
08 Apr 2020 09:46 #163178 by ioiotutu
Replied by ioiotutu on topic qtvcp interface debugging with eclipse
I used camview widget. I'm searching to use opencv to make measure and part recognition. I have to manipulate imagines, filter etc. The code is not simple so a debugger would be usefull!
Thanks.
