My QTDragon issues
12 Apr 2020 16:27 #163811 by Bruedney
My QTDragon issues was created by Bruedney
Hi
Rather than continuing to hijack another thread I thought I would start my own
I love the look of QT Dragon and want to use it on my CNC mill (A early version of the BF20 by Luxcut).
I had it working this morning in the office with no startup errors and my custom hals. Moved it into the workshop and hooked it up to the mill and the VCPWindow error came back along with a new one.
For some stange reason the QTDragon ui and handler files that I had copied into my config dir had disappeared and the bookmark to the /usr/share/qtvcp/screens dir had gone too. weird!
Anyway, I copied the 2 files back to the config dir and the VCPwindow error is now gone again.But...
Now when I start the machine and hit Home All the machine moves a little and then I get the following error
"Traceback (most recent call last):
File "/usr/lib/python2.7/dist-packages/qtvcp/widgets/basic_probe.py", line 214, in send_error
self.proc.writeData(message)
AttributeError: 'BasicProbe' object has no attribute 'proc'"
I attach an archive of my Config folder in the hope that someone (Chris?) can help me solve this issue.
The machine works fine using a standard Axis setup
Cheers
Bruce
File Name: Luxcut_DM20VS.tar.gz
File Size:74 KB
12 Apr 2020 17:29 #163814 by cmorley
Replied by cmorley on topic My QTDragon issues
What version of linuxcnc are you using and how did you get it?
12 Apr 2020 17:33 #163815 by cmorley
also if you didn't modify the .ui file (I thought you did in the other thread, when you said custom qtDragon) then there is not need to copy the .ui and handler files into your config.
In this way you get the most up to date files with bug fixes included. Only if you are customizing qtDragon would you want to copy the ui/handler files over.
12 Apr 2020 18:34 - 12 Apr 2020 19:47 #163823 by Bruedney
Replied by Bruedney on topic My QTDragon issues
Hi Chris
uname -a returns
4.16.12-rt5-kona-rt #1 SMP PREEMPT RT Fri Jun 8 10:39:47 JST 2018 x86_64 x86_64 x86_64 GNU/Linux
Linuxcnc is 2.8.0-pre1-5634-gfc53605ea
It is Mint 19.1 that has been updated as per the instructions found here.
So if I delete the ui and handler files it should be OK?
Thanks again
Bruce (I am going to get this Linux thing sorted!)
Last edit: 12 Apr 2020 19:47 by Bruedney.
13 Apr 2020 12:34 #163894 by cmorley
Deleting the files should work. I just wonder if the files are old versions.
13 Apr 2020 23:17 #163921 by Bruedney
Hi Chris
I still get this error after Home All gives a short Z move and then the error
Cheers
Bruce
14 Apr 2020 01:06 #163923 by Bruedney
OK fixed the basic_probe error but still can't home
Running from terminal I get this error
[QtDesigner.QTVCP.QT_ACTION][INFO] Homing Joint: -1 (qt_action.py:90)
joint 2 following error
emc/task/taskintf.cc 942: Error on joint 2, command number 80
Cheers
Bruce
14 Apr 2020 02:02 #163925 by Bruedney
FIXED IT
Base period was different between the towo configs
Set the base period in QT Dragon to 60000 (same as in Axis) and the machine now homes
WOOHOO!!!
14 Apr 2020 10:56 #163959 by cmorley
Thank you for the update - wow I'm not sure I would have suggested that. I wonder how that is related.
anyways excellent!
28 May 2021 04:58 #210510 by ikkuh
Replied by ikkuh on topic My QTDragon issues
Would be nice if you shared how you fixed that error
Time to create page: 0.864 seconds
