No module named qtvcp
27 Apr 2020 08:04 #165818 by prochj51
No module named qtvcp was created by prochj51
I added link to qtvcp_plugin.py,
but when I run designer a get this
prochj51@prochj51linuxCNC:~$ designer -qt=5
  File "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python/qtvcp_plugin.py", line 22, in <module>
    from qtvcp.plugins.simplewidgets_plugin import *
ImportError: No module named 'qtvcp'
Segmentation fault
the link should be fine
prochj51@prochj51linuxCNC:/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python$ ls -l qtvcp_plugin.py
lrwxrwxrwx 1 root root 62 Apr 27 14:16 qtvcp_plugin.py -> /usr/lib/python2.7/dist-packages/qtvcp/plugins/qtvcp_plugin.py
so the plugin folder
prochj51@prochj51linuxCNC:/usr/lib/python2.7/dist-packages/qtvcp/plugins$ ls
actionbutton_plugin.py   jogincrements_plugin.pyc  status_adjustment_bar_plugin.py
actionbutton_plugin.pyc  led_plugin.py             status_adjustment_bar_plugin.pyc
basic_probe_plugin.py    led_plugin.pyc            status_label_plugin.py
basic_probe_plugin.pyc   overlay_plugin.py         status_label_plugin.pyc
camview_plugin.py        overlay_plugin.pyc        status_slider_plugin.py
camview_plugin.pyc       qtvcp_plugin.py           status_slider_plugin.pyc
container_plugin.py      qtvcp_plugin.pyc          tab_widget_plugin.py
container_plugin.pyc     screenoptions_plugin.py   tab_widget_plugin.pyc
dialog_plugin.py         screenoptions_plugin.pyc  toolbutton_plugin.py
dialog_plugin.pyc        simplewidgets_plugin.py   toolbutton_plugin.pyc
graphics_plugin.py       simplewidgets_plugin.pyc  versa_probe_plugin.py
graphics_plugin.pyc      state_label_plugin.py     versa_probe_plugin.pyc
__init__.py              state_label_plugin.pyc    widgets_plugin.py
__init__.pyc             state_led_plugin.py       widgets_plugin.pyc
jogincrements_plugin.py  state_led_plugin.pyc
Thanks for ideas
Jiri
27 Apr 2020 20:20 #165885 by cmorley
Replied by cmorley on topic No module named qtvcp
open up designer
click on help
then plugins
see if there is something like libpyqt5.so or libpyqt5_py2.so present or both
28 Apr 2020 00:26 #165901 by prochj51
Replied by prochj51 on topic No module named qtvcp
They are both present
28 Apr 2020 00:34 #165904 by cmorley
Can you either rename libpyqt5.so to libpyqt5_py3.so or remove it.
I think that might be a problem.
You need to be sudo to do that.
28 Apr 2020 00:43 #165906 by prochj51
Perfect, it works.
Thanks a lot
Jiri
Time to create page: 0.259 seconds
