hal setup for probe
- Thank you received: 2181
12 Sep 2020 18:17 #181906
Replied by cmorley on topic hal setup for probe
To be clear the other probing routines work?
Does the machine start to move ?
It's timing out (probably after 60 s?) I don't understand the other error unknown oword number.
I've never used calibration = but testing the sim gives a different error
'G38.2 move finished without making contact.' which is expected with no probe...
I wont be able to look at this again for a while off to travel to work.
Hopefully Jim (qtdragob author) will see it and comment.
Chris
Chris
- lllars
- Thank you received: 3
12 Sep 2020 19:14 #181917
by lllars
Replied by lllars on topic hal setup for probe
Yes the machine moves and seems to complete the calibration routine. It gets the surface height, then jogs x and z-down into the hole. Probes both ways in x and y directions, probes both ways again, and then z-up when done.
The other routine I've tried is probing for outside edges and corners. That one seems to work 100% correctly, in that it zeros out the g54 positions when done. Still all zeros in the 3 rows though. I also assume the position is a bit off since the probe is not calibrated. It doesn't even know the diameter of the probe tip.
Thanks for your help thus far Chris. I hope you enjoy your trip.
- lllars
12 Sep 2020 20:44 #181925
by lllars
I've made some progress.
First of all I went through the console output and tracked down and resolved a lot of the errors and warnings. It doesn't seem like any of them were related to the problem at hand, but at least the console output is a little cleaner now.
After that cleanup I tried probe calibration again and got the same result as I was getting before. So then, since Chris had mentioned it was timing out, I bumped up the feed speeds a tried again, and that time it succeeded! Console output attached.
Unfortunately the results don't look right. My probe has a 0.125" ball and I'm probing a 0.562" ID hole. I've attached a photo of the results below. It looks like it calculated my probe diameter to be 0.446". Please take a look and make sure I am doing this correctly. Am I entering the 0.562" diameter in the right field? And am I interpreting the results correctly?
Another issue is that the results don't appear to be getting saved anywhere. They are gone when I restart linuxcnc. Are they supposed to be getting saved? If not, there must at least be some config variable where I can put the probe diameter...
Time to create page: 0.494 seconds
