Camview Embedded In Axis
- phillc54
- Thank you received: 2100
18 Sep 2020 04:04 #182623
by phillc54
Camview Embedded In Axis was created by phillc54
I have an issue with embedding camview in Axis where the window doesn't fill the tab.
If I resize with the handle at the bottom right then it resizes the video but the wind stays the original size.
I tried the -m and -g options that I saw in Gladevcp but it made no difference.
I does seem to work correctly in Gmoccapy.
- Thank you received: 7504
04 Oct 2020 12:32 #184854
Replied by tommylight on topic Camview Embedded In Axis
Bump.
- Thank you received: 2181
04 Oct 2020 14:36 #184866
Replied by cmorley on topic Camview Embedded In Axis
I have not been successful getting embedded object to resize properly.
It's annoying as in qt4 it worked perfectly.
But you can set the size of the window shown in AXIS by setting the size of the camview window in designer.
copy the cam_align.ui file to your config folder then open it in designer.
adjust the size by dragging the corner then resave.
Chris
Chris
The following user(s) said Thank You: phillc54, tommylight
Time to create page: 0.087 seconds
