Probing in Qtdragon
- Mara2000
- Thank you received: 3
19 Sep 2020 13:12 #182741
by Mara2000
Probing in Qtdragon was created by Mara2000
I edited sim_qtdragon according to the settings for my machine. Everything seems to be working fine but if chose probe tab, everything is grayed out. What to add to the ini or hal to make the probe functions available? Alternatively, if someone can share functional configuration with the probe.
Thank you.
Marek.
Thank you.
Marek.
- Thank you received: 2173
19 Sep 2020 18:16 - 19 Sep 2020 18:17 #182767
Replied by cmorley on topic Probing in Qtdragon
Can you run linuxcnc from a terminal and see if any pertinent info is shown.
Last edit: 19 Sep 2020 18:17 by cmorley.
The following user(s) said Thank You: Mara2000
19 Sep 2020 18:18 #182768
If you have homes the machine and still are blocked, I would think it cant find the macro library which is defined in the INI.
- Mara2000
19 Sep 2020 18:23 #182770
by Mara2000
Replied by Mara2000 on topic Probing in Qtdragon
Ok, thank you. The machine is homed. But folder with macros is not include sim_qtdragon. I'll try to work it out tomorrow.
19 Sep 2020 18:29 #182772
Should be in your linuxcnc/nc_files folder maybe under probe or maco/probe
Time to create page: 1.619 seconds
