Homing and Unhoming Actions
- phillc54
- Thank you received: 2100
09 Oct 2020 21:24 #185532
by phillc54
Homing and Unhoming Actions was created by phillc54
ACTION.SET_MACHINE_UNHOMED(-1) doesn't seem to behave correctly in that it only unhomes a single joint, in my case joint 2 which is the Z axis.
I assumed it should act similar to ACTION.SET_MACHINE_HOMING(-1) which does home all joints.
- Thank you received: 7504
10 Oct 2020 16:44 #185643
Replied by tommylight on topic Homing and Unhoming Actions
bump
- Thank you received: 2181
12 Oct 2020 13:01 #185863
Replied by cmorley on topic Homing and Unhoming Actions
hmm it seems to work in qtdefault.
Is this homing code in the files you posted ?
- phillc54
12 Oct 2020 18:08 #185894
by phillc54
Replied by phillc54 on topic Homing and Unhoming Actions
Yes, it only seems to unhome Z
12 Oct 2020 21:27 #185910
In the version i have of your screen i don't see a home home all button. The Home all button is non active after homing.
- phillc54
13 Oct 2020 01:39 - 13 Oct 2020 01:41 #185925
by phillc54
Well, I managed to thorougly confuse myself here, sorry all unhome works fine:
If all axes are homed and say we unhome Z then it unhomes.
If I then try to unhome X or Y they rehome rather than unhome.
The home/unhome code are in joint_homed and joint unhomed functions.
I also seem to be having some pathing problems:
I have a little sim test panel that I would like to put in a sim subdirectory but I cannot get it to work unless it is in the config directory. It is called from qtplasmac/qtplasmac_gui.tcl. You can see some other the combos I tried in qtplasmac_gui.tcl.
I cannot get the -H option to work from the ini file at all. I was hoping to call qtplasmac_gui.tcl from this option and leave postgui.hal for the users. At this stage the only way I can get it to work it to name qtplasmac_gui.tcl as the postgui_halfile in the ini file and call postgui.hal from there. You can see some of the combos I tried in the ini file.
Last edit: 13 Oct 2020 01:41 by phillc54.
14 Oct 2020 00:05 #186064
Ahh I see that homing issue - I'll look at it.
-H oops that's cause I didn't put code to actually do this in qtvcp.... almost done
Path problem - i'll look at your config code see if I can figure it out.
Chris
Chris
14 Oct 2020 01:07 #186068
Ok pushed homing fix and -H fix.
I see the Path problem - will look at it soon.
Chris
Chris
- phillc54
14 Oct 2020 01:22 - 14 Oct 2020 02:17 #186072
by phillc54
Great, thanks Chris, I'll take a peek tomorrow.
EDIT:
pathing works fine on the -H option:
if i have it in the config directory this works:
DISPLAY = qtvcp -c qtplasmac -H qtplasmac_gui.tcl qtplasmac
and if I have it in the subdirectory qtplasmac then this works:
DISPLAY = qtvcp -c qtplasmac -H qtplasmac/qtplasmac_gui.tcl qtplasmac
EDIT:
Last edit: 14 Oct 2020 02:17 by phillc54.
14 Oct 2020 16:54 #186130
ok pushed path work into master - setting direct paths for ui/handler/qrs/qss should work fine now.
If all is good i will cherry pick it back to 2.8 later
Chris
Chris
Time to create page: 1.295 seconds
