qtdragon tool table issues
6 years 2 weeks ago #186267 by cmorley
Replied by cmorley on topic qtdragon tool table issues
Yes I think that is the trouble...'jog' and the degree sign probably break qtvcp jog selection. I'll look at the code and see if I can make it behave better.
I assume those settings are used by something else?
6 years 2 weeks ago #186275 by keyboard
Replied by keyboard on topic qtdragon tool table issues
The degrees, were there before, and I left them in, for the 4th axis I plan for future. I will take it out , if it will correct it for now ands try..
Thanks.
6 years 2 weeks ago #186474 by lllars
Replied by lllars on topic qtdragon tool table issues
Finally getting around to testing these fixes... Seems to be working perfectly so far. I can enter negative values and I'm not getting any tool wear entries. Thanks Chris!
6 years 2 weeks ago #186487 by keyboard
Can you guide me how to update these fixes. thanks
6 years 2 weeks ago #186491 by lllars
All I had to do was run in a terminal:
sudo apt-get update sudo apt-get upgrade
That installed the latest version of linuxcnc-uspace, along with a bunch of other unrelated updates. I did not have to modify any config files or do anything else.
Note that you'll need to be on the master version of linuxcnc for that to work. I.e. something like this in your /etc/apt/sources.list:
deb http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt
6 years 2 weeks ago #186513 by keyboard
Thanks for the quick reply.
I could not update, even after making the repository changes.
my version is LINUXCNC - 2.9.0-pre0-2780-g9f6930741
I get the following:
Hit:1 xhttp://deb.debian.org/debian buster InRelease
Hit:2 xhttp://security.debian.org/debian-security buster/updates InRelease
Hit:3 xhttp://deb.debian.org/debian buster-updates InRelease
Get:4 xhttp://linuxcnc.org buster InRelease [28.5 kB]
Err:4 xhttp://linuxcnc.org buster InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 3CB9FD148F374FEF
Reading package lists... Done
W: GPG error: linuxcnc.org buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 3CB9FD148F374FEF
E: The repository ' linuxcnc.org buster InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Target Sources (base/source/Sources) is configured multiple times in /etc/apt/sources.list:25 and /etc/apt/sources.list:27
Time to create page: 0.277 seconds
