Preferences File Behaviour
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
01 Dec 2020 00:57 - 01 Dec 2020 01:50 #190741 by phillc54
Preferences File Behaviour was created by phillc54
I have some strange behaviour when saving/loading preferences. I have the following functions in a module:
Warning: Spoiler!
The reload function is called on startup and behaves correctly for both True and False.
After startup if the reload function is called then it behaves correctly.
After the save funcion is called, the Origin in the prefs file correctly reflects the state. Then when reload is called it gives a message in the terminal 'bool' object has no attribute 'lower' and the Origin in the preference file is always set to False as is the parent.origin variable.
Warning: Spoiler!
All float, int and str preferences work correctly.
EDIT:
I converted the lines to the below and it works correctly:
Warning: Spoiler!
EDIT 2: I should also add that I have several other bool preferences that are only loaded at startup and saved at shutdown and they all behave correctly.
Last edit: 01 Dec 2020 01:50 by phillc54.
01 Dec 2020 21:28 #190833 by cmorley
Replied by cmorley on topic Preferences File Behaviour
I'll try to look into this soon. Is this with python3?
  • phillc54
  • Platinum Member
  • Platinum Member
01 Dec 2020 21:56 #190837 by phillc54
Replied by phillc54 on topic Preferences File Behaviour
Yes, but I haven't tried on python2. Not a big issue as the workaround does work well. If I get a chance today I will try on python2.
  • phillc54
  • Platinum Member
  • Platinum Member
01 Dec 2020 23:15 #190839 by phillc54
Identical behaviour on python2.
Time to create page: 0.127 seconds
