Widgets Mdi Touchy
- hottabich
- Thank you received: 96
07 Dec 2020 16:06 #191322
by hottabich
Widgets Mdi Touchy was created by hottabich
After Linuxcnc updates, when adding the Mdi Touchy widget to QtDragon, Dro A does not work. Please tell me how to fix it. Thank you!
- Thank you received: 2181
07 Dec 2020 17:28 #191332
Replied by cmorley on topic Widgets Mdi Touchy
- hottabich
07 Dec 2020 21:29 - 07 Dec 2020 21:34 #191357
by hottabich
Replied by hottabich on topic Widgets Mdi Touchy
Thanks for attention. But without the widget, Dro-A counts. It all started after changing the speed sliders.
If the A axis is number 4 then the mm-inch dimension is switched.
Last edit: 07 Dec 2020 21:34 by hottabich.
08 Dec 2020 01:02 #191367
you working in 2.8?
08 Dec 2020 01:06 #191368
also which sim from your attachment are you testing with?
- hottabich
08 Dec 2020 06:21 #191387
by hottabich
I am using Linuxcnc 2.8 as in the screenshot. Simka with 2.8 and mine, if you remove the mdi touchy widget, work the same way.
08 Dec 2020 07:33 #191392
I can't duplicate the problem.
I do see you have an error related to the resource file but I'm not sure that's related.
- hottabich
08 Dec 2020 10:02 - 08 Dec 2020 10:18 #191403
by hottabich
Why is the mdi touchy widget breaking the A axis? No problem without a widget. Please upload the config and you will see what I am asking. The second config is the same but without the widget.
Last edit: 08 Dec 2020 10:18 by hottabich.
08 Dec 2020 17:31 #191434
In my test - both seem to work fine.
Are you using 2.8.1?
Are you sure linuxcnc is running the .ui file you think it is?
You can check the output in the terminal to confirm what .ui and handler it's using.
Chris
Chris
- hottabich
08 Dec 2020 21:05 - 08 Dec 2020 21:08 #191445
by hottabich
Without the widget, the commands G20, G21 change the bit width of the A axis dro, but with the widget they do not. I believe the two decimal places are correct and should not change in the designer's opinion. Axis A is practically working. Maybe I'm wrong. Thanks for attention.
Last edit: 08 Dec 2020 21:08 by hottabich.
Time to create page: 0.153 seconds
