Gcode Editor Find Previous
- phillc54
- Thank you received: 2100
16 Dec 2020 02:27 #192093
by phillc54
File Manager Find Previous was created by phillc54
The find previous button keeps giving the following error:
File "/home/phill/git/linuxcnc-dev/lib/python/qtvcp/widgets/gcode_editor.py", line 768, in nextCall
next(self)
TypeError: GcodeEditor object is not an iteratorPlease Log in or Create an account to join the conversation.
- Thank you received: 2181
16 Dec 2020 03:32 #192095
Replied by cmorley on topic File Manager Find Previous
do you mean gcode editor search function?
- phillc54
16 Dec 2020 03:34 #192096
by phillc54
Replied by phillc54 on topic File Manager Find Previous
Oops.
Yep, that's the one.
16 Dec 2020 03:38 #192098
i'll look into it (haven't tested that in a long while)
- phillc54
27 Dec 2020 06:34 #193274
by phillc54
Replied by phillc54 on topic Gcode Editor Find Previous
I changed the title to a more correct one but have another question.
Some time back it was possible to hide the gcode lexer button and the python lexer button but it has changed and I cannot work out how to do it any more. Is it possible to allow this to happen again?
27 Dec 2020 10:39 #193280
Replied by cmorley on topic Gcode Editor Find Previous
Sorry I forgot about the broken search function - fixed now.
Added some code to help.
If there is a convenience function needed to set a common set of controls visible (ie setting up modes of operations) then let me know
But here are the raw functions samples:
w=self.w.gcodewidget
w.toolBar.hide() # hides everything
w.pythonLexerAction.setVisible(False)
w.gCodeLexerAction.setVisible(False)
w.openAction.setVisible(False)
w.newAction.setVisible(False)
w.saveAction.setVisible(False)
w.exitAction.setVisible(False)
w.label.setText('<b>Edit mode title label</b>')
- phillc54
27 Dec 2020 11:07 #193284
by phillc54
Thanks Chris, I can close my PR then, although there are some status tip changes you could get from it.
27 Dec 2020 11:12 #193287
Sorry I didn't see that either - I'll incorporate your work too.
Chris
Chris
Time to create page: 0.135 seconds
