Home button for A-axis
14 Jan 2021 16:29 #195372 by lllars
Home button for A-axis was created by lllars
How would I go about adding a "home" button for the A-Axis to QtDragon? Currently I have home buttons for X, Y, and Z, but A has a "goto zero" button instead.
I tried copying the home button from Z (btn_home_z), renaming it to btn_home_a and and changing "joint" under "Dynamic Properties" from 2 to 3. But, that doesn't seem to work.
14 Jan 2021 17:08 #195376 by cmorley
Replied by cmorley on topic Home button for A-axis
What version of linuxcnc are you using?
make sure 'home action' is checked in the properties.
Set the joint number and the axis letter in the properties.
14 Jan 2021 17:10 #195378 by cmorley
Oh and make sure it's an ActionButton.
So don't copy the other home buttons - convert the original button
14 Jan 2021 20:18 #195393 by lllars
Replied by lllars on topic Home button for A-axis
Thank you Chris. Converting the original button worked perfectly. I just needed to check the "home action" box (well, and change the text to "HOME" for aesthetics).
14 Jan 2021 20:56 #195397 by cmorley
Glad you got it worked out.
Time to create page: 0.073 seconds
