Tool offset status label
  • persei8
  • persei8's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Feb 2021 15:12 #197594 by persei8
Tool offset status label was created by persei8
When I enter offset values in the tool table or the offset table, the tool offset status label does not change. It is always 0.0. I have the index value set to 5, which is the Z offset in tool info. What exactly does the tool offset status label indicate?
03 Feb 2021 15:38 #197598 by cmorley
Replied by cmorley on topic Tool offset status label
It gives the tool offset of the current tool.
use index_number to pick the axis 0=x 1=y etc.
  • persei8
  • Platinum Member
  • Platinum Member
03 Feb 2021 16:59 #197603 by persei8
Replied by persei8 on topic Tool offset status label
Aha, so the index refers to the machine axis, not the index in the tool table. Also, G43 has to be active. Thank you.
03 Feb 2021 19:00 #197610 by cmorley
yes - but i don't think it changes units on g20/21- yet
06 Feb 2021 23:10 #197890 by cmorley
ok tool offsets and tool diameter follow units now
Time to create page: 0.739 seconds
