Latest update broke something
- Thank you received: 2181
Your debug statements seem to indicate that your INI/HAL files are still mixed in with the QTVCP handler and .ui code:
Machine configuration directory is '/home/jim/linuxcnc/configs/qtdragon_hd/qtdragon'
I would have expected that to be:'/home/jim/linuxcnc/configs/qtdragon_hd'
This indicates the same thing:
[QTvcp][INFO] Logging to "/home/jim/linuxcnc/configs/qtdragon_hd/qtdragon/qtdragon.log" (logger.py:100)
So the INI/HAL files should be separated from the handler/.ui etc files by a config folder the same basename as the screen.
Can you confirm my understanding of your config is right?
- persei8
- Thank you received: 133
- persei8
I'll look into the qss file problem. Thanks.
- tommieh
I moved the ui, _handler, resources, qrc, qss into a subdirectory.
These 5 files are now in /home/tommie/linuxcnc/configs/qtdragon/qtdragon/
That gets the UI screen to start.
But I can only get the style sheet (qss) to load without error if it is in /usr/share/qtvcp/screens/qtdragon/
I havent looked into qss problem yet.
I'm working long hours night shift for a 15day shutdown..
My window of opportunity is small. Sorry for the inconvenience.
- tommieh
I just noticed that when I start designer, it has no linuxcnc widgets anymore.
Just in case I ran install again: /usr/lib/python2.7/dist-packages/qtvcp/designer/install_script
But everything was reported as newest version and installed already.
When I start designer with:
$designer -qt=5
It shows:
('Qtvcp python plugin found:', '/home/cnc/.designer/plugins/python/qtvcp_plugin.pyc')
[QtDesigner][INFO] Logging to "/home/cnc/qtdesigner.log" (logger.py:100)
tool_mmap_user(): file open fail: No such file or directory
tool_mmap_user(): no mmap file,continuing
mmap tool data not available, continuing emc/usr_intf/axis/extensions/emcmodule.cc
File "/home/cnc/.designer/plugins/python/qtvcp_plugin.py", line 42, in <module>
from qtvcp.plugins.screenoptions_plugin import LcncScreenOptionsPlugin
File "/usr/lib/python2.7/dist-packages/qtvcp/plugins/screenoptions_plugin.py", line 8, in <module>
from qtvcp.widgets.screen_options import ScreenOptions
File "/usr/lib/python2.7/dist-packages/qtvcp/widgets/screen_options.py", line 46, in <module>
PATH = Path()
File "/usr/lib/python2.7/dist-packages/qtvcp/qt_pstat.py", line 43, in __init__
self.BASEDIR = os.path.abspath(os.path.join(os.path.dirname(sys.argv[0]), ".."))
AttributeError: 'module' object has no attribute 'argv'
Can someone help please?
- phillc54
- Thank you received: 2100
Maybe something else is broken?
This should have been fixed 3 days ago, have you updated LinuxCNC since then?
github.com/LinuxCNC/linuxcnc/commit/5320...ea77bb4634a44d72bd0c
