How to get latest QtDragon?
- Thank you received: 2173
11 Mar 2021 22:29 #201891
Replied by cmorley on topic How to get latest QtDragon?
Are you running linuxcnc as an 'installed' version ie. you didn't compile the code first to run?
- turbostew
- Thank you received: 8
11 Mar 2021 22:35 #201893
by turbostew
Replied by turbostew on topic How to get latest QtDragon?
Can I just grab the handler file from github?
- turbostew
11 Mar 2021 22:42 #201896
by turbostew
I did not compile. Can I just grab the whole QtDragon_HD directory in github?
11 Mar 2021 22:43 #201897
I would grab the .ui file too. Try that - it should work - I don't see any related widget code changes needed.
11 Mar 2021 22:44 #201898
I have to got to work soon so can't help much further today
The following user(s) said Thank You: turbostew
- persei8
- Thank you received: 133
12 Mar 2021 01:08 #201916
by persei8
Replied by persei8 on topic How to get latest QtDragon?
The HD version of qtdragon has a resolution of 1920 x 1080. This takes the whole screen of an HD monitor. It is started in maximized mode with no title bar. If the bottom is cut off, you likely have the bottom panel turned on. To turn it off in debian, right click the panel, select panel settings and enable auto-hide panel. Other distros may have similar settings, I don't know as I only use debian. HTH
The following user(s) said Thank You: mor
- turbostew
12 Mar 2021 20:23 #202007
by turbostew
Thanks Jim,
I see this now, I had to hide top and bottom bars. Funny it has issue in 4k screen, but once fixed in 1920x1080 screen by hiding bars it now works in 4k.
- mor
30 Mar 2023 12:19 #267905
by mor
Replied by mor on topic How to get latest QtDragon?
For Raspberry Pi OS, under Panel Preferences -> Advanced, you have to enable Automatic Hiding AND also change "Size when minimized = 0 pixels"; default of 2 pixels didn't work.
Time to create page: 1.530 seconds
