QtDragon DRO decimal places
02 Apr 2021 23:53 #204582 by cmorley
Replied by cmorley on topic QtDragon DRO decimal places
I wonder if this is common enough to add as a settings option?
03 Apr 2021 15:58 #204632 by turbostew
Replied by turbostew on topic QtDragon DRO decimal places
Well IMHO, for a router 10th of thousandths is just annoying to see, but for a mill tenths (of a thousandths) is a must. Maybe a ultra-precision mini mill might go out one more place.
08 Nov 2022 20:54 - 08 Nov 2022 21:01 #256242 by turbostew
It has been a 1.5 years since last post, seems things have changed. How do I change (preferred method) QtDragon DRO precision in the latest master?
Last edit: 08 Nov 2022 21:01 by turbostew.
09 Nov 2022 14:04 #256289 by cmorley
What version of linuxcnc are you using?
In master this should work in your stylesheet file. you can edit it from the built on editor in qtdragon. press f12 to launch it.
change the template to what you like (as before):
DROLabel {
font: 25pt "Lato Heavy";
qproperty-imperial_template: '%9.4f';
qproperty-metric_template: '%10.3f';
qproperty-angular_template: '%11.2f';
The following user(s) said Thank You: turbostew
10 Nov 2022 04:38 - 10 Nov 2022 04:39 #256317 by cmorley
For completeness here is hoe to set origin/tool offset view with stylesheets too.
ToolOffsetView {
font: 20pt "Lato Heavy";
qproperty-imperial_template: '%9.1f';
qproperty-metric_template: '%10.1f';
OriginOffsetView {
font: 12pt "Lato Heavy";
Last edit: 10 Nov 2022 04:39 by cmorley.
18 Nov 2022 05:21 - 18 Nov 2022 05:22 #257008 by turbostew
Thanks!
One more thing, I want to change my feedrate DRO to add a decimal place. Whole numbers in inches is too granular....
Last edit: 18 Nov 2022 05:22 by turbostew.
18 Nov 2022 18:21 #257052 by cmorley
I pushed the fix to this to 2.9 but if you don't want to update this should do the same:
#status_jog_linear{
qproperty-textTemplate: '%.1f';
18 Nov 2022 20:38 #257063 by turbostew
I mean this readout....
18 Nov 2022 22:25 #257074 by cmorley
status_act_feedrate{
20 Nov 2022 19:52 #257175 by turbostew
Thanks! Took me a while but by deduction I figured out the complete code is:
StatusLabel#status_act_feedrate{
Time to create page: 3.060 seconds
