QtDragon startup issues if limit/home switch tripped
01 Apr 2021 10:13 - 01 Apr 2021 10:15 #204394 by turbostew
One thing, the only way I can override limits is with the button on the floating msg box. I cannot check the override check box, won't allow it. I fixed it by changing this line in the init_widgets function. (I have actually used this mod for weeks)
self.w.chk_override_limits.setEnabled(True) ##DKS: was False
Kent
Last edit: 01 Apr 2021 10:15 by turbostew.
01 Apr 2021 10:15 #204396 by cmorley
can you post the handler file you are using?
01 Apr 2021 10:18 #204397 by cmorley
also can you see the check marks of the other options? IIRC one style has missing checkmark images
01 Apr 2021 14:12 - 01 Apr 2021 14:13 #204416 by turbostew
Here you go.... My qss works great.
Last edit: 01 Apr 2021 14:13 by turbostew.
01 Apr 2021 16:49 #204436 by cmorley
Ok I think I understand why.
With my testing i always had the screen running before tripping the limit.
I think if the limit is set before the screen starts, it would not send the proper gobject message to catch it.
I added a change so it always forces the message on start up - I bet it works properly now.
Time to create page: 0.296 seconds
