QtDragon_hd does not unhome an axis.....
- turbostew
- Thank you received: 8
31 Mar 2021 10:02 - 31 Mar 2021 10:03 #204228
by turbostew
QtDragon_hd does not unhome an axis..... was created by turbostew
So I notice when I am homed, I can press the home button for an axis, I would expect that axis to "unhome" and turn red. What really happens is when you press the button the axis immediately rehomes itself. I tried to debug this and the code will never get a True from "self.w["dro_axis_{}".format(axis)].property('homed')". (but the DRO is green)
- def btn_home_clicked(self):
- - joint = self.w.sender().property('joint')
- - axis = INFO.GET_NAME_FROM_JOINT.get(joint).lower()
- - print (axis)
- - print (self.w["dro_axis_{}".format(axis)].property('homed'))
- - if self.w["dro_axis_{}".format(axis)].property('homed') is True:
- -- ACTION.SET_MACHINE_UNHOMED(joint)
- - else:
- -- ACTION.SET_MACHINE_HOMING(joint)
- - print (axis)
- - else:
Last edit: 31 Mar 2021 10:03 by turbostew.
- Thank you received: 2181
31 Mar 2021 10:23 #204231
Replied by cmorley on topic QtDragon_hd does not unhome an axis.....
nice catch.
change the 'homed' to 'isHomed' in the line:
- turbostew
31 Mar 2021 12:38 #204246
by turbostew
Replied by turbostew on topic QtDragon_hd does not unhome an axis.....
Thank You QtDragon Master!!!!!
Time to create page: 0.200 seconds
