Random Error
- snowgoer540
- Thank you received: 907
18 Apr 2021 14:41 #206324
by snowgoer540
Random Error was created by snowgoer540
Today QtPlasmaC crashed for no apparent reason (it was just sitting idle).
This was the error associated with the crash:
I did have Designer open, and closed it and closed without saving changes. I can't see what the correlation would be, but I received the error message in QtPlasmaC right around the same time. I did try to duplicate the scenario, but to no avail.
The error seemed to be random. Not sure if it needs an exception, or what could be going on?
File "/home/plasma/linuxcnc-dev/lib/python/qtvcp/widgets/screen_options.py", line 305, in on_periodic
e = self.error.poll()
error: Error buffer invalidI did have Designer open, and closed it and closed without saving changes. I can't see what the correlation would be, but I received the error message in QtPlasmaC right around the same time. I did try to duplicate the scenario, but to no avail.
- Thank you received: 2181
21 Apr 2021 00:05 #206612
Replied by cmorley on topic Random Error
That is hard to say what happened. I bet it was caused by the closing of designer but it might be a race condition, so hard to trigger.
I could trap the error to print something then we might get more info in the long run.
- snowgoer540
21 Apr 2021 04:39 #206621
by snowgoer540
Saw you pushed a trap as mentioned. Thank you, I will keep an eye out if I see the error again and report back if there is any information that comes out of it.
Probably a 1:1,000,000 condition. Those are the worst.
Replied by snowgoer540 on topic Random Error
Time to create page: 0.551 seconds
