How to choose camera device used by cam_align?
- plovdiv
25 May 2021 16:45 #210269
by plovdiv
I'ld like to try. You've got a diff for me?
Replied by plovdiv on topic How to choose camera device used by cam_align?
yes qtvcp in 2.8 does not support the -o option it seems
I can add it but you'd have to wait for next release or modify the code yourself.
- Thank you received: 2181
25 May 2021 16:50 #210272
Replied by cmorley on topic How to choose camera device used by cam_align?
Ok here you go:
Let me know how it goes - I'll push to 2.8 if all is good.
Chris
Chris
- plovdiv
25 May 2021 17:13 #210277
by plovdiv
patching cam_align_handler.py and camview_widget.py suceeded
But there is no such file qtvcp.py on my 2.8.1 installation.
25 May 2021 17:42 #210281
There is such a file somewhere.
Are you using a compiled version or an installed version?
- plovdiv
26 May 2021 03:19 #210316
by plovdiv
I Installed via iso image and updated with apt-get
"locate qtvcp.py" gives nothing neither does "locate qtvcp.pyc"
26 May 2021 07:37 #210338
try locate qtvcp
the .py is removed and it's probably in bin/
Sorry I don't have an installed version handy to check
- plovdiv
27 May 2021 06:14 #210436
by plovdiv
I could locate and patch the file as /usr/bin/qtvcp
The -o option now is accepted.
But I don't get a video display in the axis tab:
# Embed tabs
EMBED_TAB_NAME= fideo
# -Wn wait for 'name' -c give 'name'
EMBED_TAB_COMMAND= halcmd loadusr -Wn qtvcp_embed qtvcp -d -o 0 -c qtvcp_embed -x {XID} cam_align
The "fideo" tab says: "No image"
But with standalone "mpv av://v4l2:/dev/video0" the stream is displayed.
# Embed tabs
27 May 2021 20:09 #210486
qtvcp uses opencv for camera interfacing.
it's possible your camera is not compatible with the default settings.
specifically it assumes the camera gives BGR and converts to RGB
(cv2.COLOR_BGR2RGB)
I had assumed you did get a picture but needed a different camera selection.
Can you try a different camera to see if it works?
also checking in the terminal may give some clue (but you might have to look carefully)
(cv2.COLOR_BGR2RGB)
Time to create page: 0.123 seconds
