reading tool table from qtdragon_handler.py
- mb_cnc
02 Jul 2021 16:38 #213510
by mb_cnc
reading tool table from qtdragon_handler.py was created by mb_cnc
Does anyone know of a way to read a specific tools data in the tool.tbl file from qtdragon_handler.py using python?
thanks
thanks
- Thank you received: 2181
02 Jul 2021 23:15 #213532
Replied by cmorley on topic reading tool table from qtdragon_handler.py
can you give a little more info?
there are a couple ways depending on what info you want.
- mb_cnc
03 Jul 2021 11:47 #213572
by mb_cnc
Replied by mb_cnc on topic reading tool table from qtdragon_handler.py
I am using an electronic tool length setter and have modified the default silverdragon gui to separate tool length and z offset measuring. I have also modified qtdragon_handler.py with the coding changes as it seemed like the logical choice. I understand python but not at an expert level.
I was thinking to create a tool in the table just to store the spindle Z value and then use that value as part of the formula when running tool length measuring.
The other is use the tool table x or y values to store a large diameter tool adjustment for x/y positioning over the tool length sensor.
thanks
thanks
04 Jul 2021 00:25 #213642
ok interesting.
We do something similar to get wear offsets for lathes.
tools numbers above 10000 are considered as wear information.
This requires remap to handle tool changes properly ( to add the wear offset )
you could use the linuxcnc python module to read the status of the tool_table.
linuxcnc.org/docs/2.8/html/config/python...xcnc_stat_attributes
look for 'tool_table'
in qtvcp tstat.py is used for direct tool file manipulation.
it has a function you might use:
linuxcnc.org/docs/2.8/html/gui/qtvcp_lib...tool_info_toolnumber
def GET_TOOL_INFO(self, toolnum):
self.current_tool_num = int(toolnum)
self._reload()
return self.toolinfo
The linuxcnc python module method is easiest and safest if it will do what you want.
self._reload()
Time to create page: 1.097 seconds
